zlib build problem
Ralf Corsepius
ralf.corsepius at rtems.org
Sat Jul 30 10:30:05 UTC 2011
On 07/30/2011 12:04 PM, Sebastien Bourdeauducq wrote:
> On Sat, 2011-07-30 at 10:47 +0200, Sebastien Bourdeauducq wrote:
>>> The breakdown you describe, could indicate you to be using a toolchain
>>> which doesn't have the RTEMS newlib-patches applied (c.f. the latest
>>> newlib patch in contrib/crossrpms/patches on CVS-HEAD).
>> Could be. I will try to recompile the toolchain with this patch and let
>> you know.
Can't reproduce on neither Fedora 14 nor 15,
using the rtems-4.11-lm32-rtems4.11-gcc-4.5.3-5 rpms.
What I also do not understand is you telling us to be using the rpms and
at the same time telling us to be recompiling.
> The problem is still present with newlib-1.19.0-rtems4.11-20110724.diff
> (and gcc-core-4.5.3-rtems4.11-20110426.diff +
> gcc-g++-4.5.3-rtems4.11-20110426.diff).
I'd guess you either have some broken customisations applied or you are
not "rebuilding" correctly.
Ralf
P.S.: Please fix your mail server - I am receiving an absurd "out of
office/I am sick" mail in response to mails to you.
