Issue in blackfin toolchain
Rohan Kangralkar
rohankangralkar at yahoo.com
Thu Jun 9 23:54:50 UTC 2011
Hi,
I am still stuck up with the debugging issue.
I try to build the system with the debug flags with no optimization. I have
used the pre-built 4.11 toolchain for blackfin.
Is this an issue with rtems port of the toolchain? Can anyone suggest more
test that i should be performing?
If this is not the group that deals with toolchain issues to which group
should this issue be reported to as a bug?
To which mailing list do you want me to move this thread to the rtems-gdb
mailing list, gnu-gdb or adi-gdb?
Thanks and regards
Rohan Kangralkar
On Tue, May 24, 2011 at 11:38 AM, Rohan Kangralkar <rohan.stays at gmail.com>wrote:
> Hi,
> I am not using the ADI toolchain. I am using the toolchain provided by rtems.
> *I compile my source using** bfin-rtems4.11-gcc. Then i load it
> to bfin-rtems4.11-gdb and** connect it to the bfin simulator.
> **Then i try to put a breakpoint in the file by opening then file.
> **The debugger complains that there is no such line number. Also
> **there is no optimization set while compiling. I also compile with
> the -g flag so that the debug symbols are included.** This is making
> my debugging difficult since i have to look at the** disassembly
> for debugging. Is there any way i can use the C** source for debugging.*
> I find only the RTEMS Tool Test Results <http://www.rtems.org/pipermail/rtems-tooltestresults/> mailing group on rtems. To which
> group should i move this thread to.
> Rohan Kangralkar
> Sorry I lost the mailing thread so i had to copy the mail contents.
> Unfortunately, we probably need to move this to either the
> binutils or gdb mailing lists. I am not sure which. Probably
> the gdb mailing list is more likely to produce an answer.
> Just to make sure I understand the bfin-elf gdb configuration
> includes support for a debug connection to a target that
> bfin-rtems does not? That doesn't seem correct given
> that bfin-*-* is the pattern which matches both rtems
> and elf bfin targets in gdb/configure.tgt
> And the gdb's are built from the same source tree?
> Why do you need the bfin-elf toolchain at all?
> --joel
> On 05/18/2011 10:55 AM, Rohan Kangralkar wrote:
> *>* On Wed, May 18, 2011 at 11:44 AM, Rohan Kangralkar
> *>* <rohan.stays at gmail.com <http://www.rtems.org/mailman/listinfo/rtems-users> <mailto:rohan.stays at gmail.com <http://www.rtems.org/mailman/listinfo/rtems-users>>> wrote:
> *>* On Thu, May 12, 2011 at 5:43 PM, Joel Sherrill
> *>* <joel.sherrill at oarcorp.com <http://www.rtems.org/mailman/listinfo/rtems-users> <mailto:joel.sherrill at oarcorp.com <http://www.rtems.org/mailman/listinfo/rtems-users>>> wrote:
> *>* On 05/12/2011 04:41 PM, Rohan Kangralkar wrote:
> *>* Hi,
> *>* I am using the rtems blackfin tools to build and debug my
> *>* board that contains analog devices BF527 processor.
> *>* The issue i am facing is that I am not able to place
> *>* breakpoints in some part of my c code. So the debugging is
> *>* becoming difficult. GDB complains "No line 291 in file"
> *>* even though the file has more that 300 lines of code.
> *>* What's the name of the file? There is a chance there are two
> *>* files with the same name in the executable and gdb is confused.
> *>* I have seen this before.
> *>* The name of the file is tll_fpga.c. I looked for the file in my
> *>* project and there are no files with duplicate file names.
> *>* I use the compiler, debugger provided by rtems4.11 for
> *>* debugging my application.
> *>* After some debugging and analysis of the mapping the line
> *>* number in the elf to the C code in the file using objdump
> *>* i find the following.
> *>* 1. executing the bfin-elf-objdump ( analog devices
> *>* toolchain) on the elf the following error is thrown out
> *>* BFD: Dwarf Error: mangled line number section.
> *>* 2. but the objdump from rtems does not complain.
> *>* Are they built from the same source? If not, then random
> *>* differences.
> *>* They are built from the same source.
> *>* So
> *>* How do i correct the issue in the rtems blackfin gdb?
> *>* I also observe that analog devices have their own
> *>* gdb-proxy but rtems does not provide gpd-proxy
> *>* should the gdb-proxy also be included in the rtems bfin
> *>* toolchain?
> *>* Would be good. Yes.
> *>* I have some more information about the problem. To decouple it
> *>* from the ADI toolchain, I compile my source using
> *>* bfin-rtems4.11-gcc. Then i load it to bfin-rtems4.11-gdb and
> *>* connect it to the gdb bfin simulator.
> *>* Then i try to put a breakpoint in the file by opening then file.
> *>* The debugger complains that there is no such line number. Also
> *>* there is no optimization set while compiling.
> *>* This is making my debugging difficult since i have to look at the
> *>* disassembly for debugging. Is there any way i can use the C
> *>* source for debugging.
> *>* Thankyou
> *>* Rohan Kangralkar
> *>* Joel Sherrill, Ph.D. Director of Research&
> *>* Development
> *>* joel.sherrill at OARcorp.com <http://www.rtems.org/mailman/listinfo/rtems-users> On-Line Applications Research
> *>* Ask me about RTEMS: a free RTOS Huntsville AL 35805
> *>* Support Available (256) 722-9985 <tel:%28256%29%20722-9985>
> *>* ___________________________
> *>* Thanks and regards
> Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20110609/df57a0d2/attachment.html>
