Issue in blackfin toolchain
    Mike Frysinger
    vapier.adi at gmail.com
    Fri Jun 10 18:23:08 UTC 2011
On Thu, Jun 9, 2011 at 19:54, Rohan Kangralkar wrote:
> I am still stuck up with the debugging issue.
> I try to build the system with the debug flags with no optimization. I have
> used the pre-built 4.11 toolchain for blackfin.
> Is this an issue with rtems port of the toolchain?  Can anyone suggest more
> test  that i should be performing?
> If this is not the group that deals with toolchain issues to which group
> should this issue be reported to as a bug?
> To which mailing list do you want me to move this thread to the rtems-gdb
> mailing list, gnu-gdb or adi-gdb?
if the issue is only showing up in the rtems builds, i'm not sure the
ADI guys will spend time on it
-mike
