still problem with ARM and Unlimited Task Test
Joachim Rahn
Joachim.Rahn at helmholtz-berlin.de
Wed Jun 15 13:08:03 UTC 2011
Hi Joel,
hope I don't bother you too much...
Now I found some time beside my main work to come back to my problem with the
failing Unlimited Task Test on our ARM board.
Any advice regarding the following would be welcome!!!
In fact our problem has nothing directly to do with the update between RTEMS 4.9.3 and 4.9.5 !
BTW: We now use the shared code in the BSP tree to initialize the workspace (BSP_BOOTCARD_HANDLES_RAM_ALLOCATION = TRUE)
and we compile every thing with all RTEMS and HEAP debugging on.
We now have a setup with RTEMS 4.9.3 on a AT91SAM9263-EK evaluation board from Atmel which reproduces
our data abort fault.
The problem seems to be that under some circumstances the routine
_RTEMS_task_Switch_extension(Thread_Control *executing, Thread_Control *heir)
will be called with a reference to an executing task (*executing) after
the routine
_RTEMS_task_Delete_extension(Thread_Control *executing, Thread_Control *heir)
has already deleted the certain task and a following call sequence to
_RTEMS_tasks_Free
_Objects_Free
_Objects_Shrink_information
ends up in a call to
_Heap_Free(Heap_Control *the_heap, void *starting_address)
which frees the memory used by this certain Thread_Control struct of that task and overwites the
pointer "executing->task_variables" (which now should be NULL) with some heap information.
Because "executing->task_variables" now is corrupted the call to _RTEMS_task_Switch_extension
leads to a data_abort.
GDB output of the concerning call sequences using the gdb up command looks like:
GDB stack walk: _RTEMS_tasks_Delete_extension (executing=0x23fca500, deleted=0x23fca500)
_User_extensions_Thread_delete (the_thread=0x23fca500)
_Thread_Close (information=0x2002fd98, the_thread=0x23fca500)
rtems_task_delete (id=0)
test_task (my_number=8)
_Thread_Handler ()
_Objects_API_maximum_class (api=536959452)
GDB stack walk: _Heap_Free (the_heap=0x2002fe4c, starting_address=0x23fca0a0)
_Workspace_Free (block=0x23fca0a0)
_Objects_Shrink_information (information=0x2002fd98)
_Objects_Free (information=0x2002fd98, the_object=0x23fca500)
_RTEMS_tasks_Free (the_task=0x23fca500)
_Thread_Handler ()
NOW "executing->task_variables" IS CORRUPTED !!!!!
GDB stack walk: _RTEMS_tasks_Switch_extension (executing=0x23fca500, heir=0x23fac488)
_User_extensions_Thread_switch (executing=0x23fca500, heir=0x23fac488)
_Thread_Dispatch ()
_Thread_Enable_dispatch ()
_Thread_Handler ()
By chance the pointer to "next_block->prev_size" in the call to _Heap_Free has the same location as
"executing->task_variables" in the concerning Thread_Control struct and therefore _RTEMS_task_Switch_extension
tries to access a bad memory location which of course leads to a data_abort.
May be under other circumstances one will never stumble upon this?
BTW: When I change (as a test) the definition of CPU_HEAP_ALIGNMENT in
..../rtems/cpukit/score/cpu/arm/rtems/score/cpu.h
from CPU_ALIGNMENT (which is 4) to something larger than CPU_ALIGNMENT,
the unlimited test works fine.
Any idea or advice ...?
Regards,
Joachim
On 01.03.2011 17:09, Joel Sherrill wrote:
> On 03/01/2011 07:48 AM, Joachim Rahn wrote:
>> Hi all,
>> after updating from rtems-4.9.3 to rtems-4.9.5 the "Unlimited Task Test" on my
>> ARM cpu at91sam9263 fails with a message like...
>> [...skip...]
>> task 19 ending.
>> task 20 ending.
>> task 21 ending.
>> task 7 ending.
>> task 8 ending.
>> INSN_LDR
>> data_abort at address 0x20018CD8, instruction: 0xE5932000, spsr = 0x20000013
>> active thread thread 0x0A010001
>> Previous sp=0x200629A8 lr=0x200135E0 and actual cpsr=60000097
>> 0x20038E30 0x20056EA8 0x0000117C 0x200629E0 0x200629C4 0x200135E0
>> 0x20018CB8 0x20038E30 0x20056EA8 0x20026EC0 0x20026EC0 0x20062A18
>> 0x200629E4 0x20010100 0x200135AC 0x00000000 0x00000000 0x00000000
>> 0x00000000 0x20056EA8 0x20038E30 0x60000013 0x600000D3 0x00000000
>> 0x00000000 0x20062A28 0x20062A1C 0x2000AE48 0x2000FFF8 0x20062A4C
>> 0x20062A2C 0x2000ADA0 0x2000AE24 0x521C9845 0x20056EA8 0x00000000
>> 0x00000000 0x2002ACD8 0x20062A64 0x20062A50 0x20000348 0x2000AD28
>> 0x00000008 0x00000001 0x20062A84 0x20062A68 0x2001C2D4 0x20000310
>> [...skip...]
>> which commonly means the cpu tries to access non available memory.
>> After removing the bugfix bug1718 the "Unlimited Task Test" works fine.
>> (https://www.rtems.org/bugzilla/show_bug.cgi?id=1718)
>> *** rtems-4.9.3: ./cpukit/sapi/include/confdefs.h *** unlimited task test works
>> [...skip...]
>> #define CONFIGURE_MEMORY_PER_TASK_FOR_POSIX_API \
>> _Configure_From_workspace( \
>> sizeof (POSIX_API_Control) + \
>> (sizeof (void *) * (CONFIGURE_MAXIMUM_POSIX_KEYS)) \
>> [...skip...]
>> *** rtems-4.9.5: ./cpukit/sapi/include/confdefs.h *** unlimited task test doesn't work
>> [...skip...]
>> CONFIGURE_MINIMUM_TASK_STACK_SIZE + \
>> [...skip...]
>> Any hints respectively does anyone observe the same?
> That patch wouldn't directly cause that failure.
> The only think I can see is that does change the
> amount of workspace reserved up front (by a lot).
> Is this a BSP which is in the RTEMS tree? I am
> suspicious that there isn't enough memory for
> the workspace/heap and the BSP initialization
> isn't recognizing this. Eventually the task stacks,
> heap, etc all collide, there is corruption and you crash.
> So we would need to know the following:
> + address of end of BSS
> + start of memory for heap and length
> + start of memory for RTEMS workspace and length.
> + amount of RAM
> Assuming that the workspace/heap are from end of
> BSS to the end of RAM.
>> Cheers
>> Joachim
>> ________________________________
>> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
>> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V
>> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
>> Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
>> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
>> Postadresse:
>> Hahn-Meitner-Platz 1
>> D-14109 Berlin
>> http://www.helmholtz-berlin.de
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
D-14109 Berlin
