RTEMS shell: pthread priorities printed out as rtems priorities
    Peter Dufault
    dufault at hda.com
    Sun Jun 26 17:11:29 UTC 2011
The RTEMS shell will print out the pthread priorities as what I assume are classic RTEMS task priorities, where lower means higher priority instead of the POSIX priority where a higher number is higher priority.  It caused me a moment of confusion.
I think it should print out the same POSIX priorities you assigned the tasks with the POSIX interface.  Thoughts?
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
