RTEMS shell: pthread priorities printed out as rtems priorities
    Chris Johns
    chrisj at rtems.org
    Mon Jun 27 08:11:12 UTC 2011
On 27/06/11 3:11 AM, Peter Dufault wrote:
> The RTEMS shell will print out the pthread priorities as what I assume are classic RTEMS task priorities, where lower means higher priority instead of the POSIX priority where a higher number is higher priority.  It caused me a moment of confusion.
> I think it should print out the same POSIX priorities you assigned the tasks with the POSIX interface.  Thoughts?
Maybe the kernel priority (which is the classic priority) and the API
priority should be shown. A system can have a mix of class and POSIX and
handling these differences could also be confusing.
