adjtime()
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Thu Jun  2 06:11:12 UTC 2011
Till Straumann <strauman at slac.stanford.edu> wrote:
>Currently, adjtime() basically steps the time (albeit not
>backwards if IRC) and this only if the requested difference
>is bigger than a full clock tick.
>IMO it would make sense to improve this implementation by
>- gradually adjusting the clock, i.e., absorbing the requested
>   delta over multiple clock ticks.
>- allow small adjustments (especially on architectures
>   with a high-resolution clock)
>I know that adjtime() is not posix but AFAIK there is nothing else.
>Ultimate goal would be letting an NTP client use adjtime().
>Maybe even a better idea would be incorporating the Mills
>algorithm into the system clock and add adjtimex() for tuning
>it with an NTP client.
>RFC
>- Till
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-users
