shell/telnetd/SpaceWire question
    Thomas Doerfler
    Thomas.Doerfler at embedded-brains.de
    Fri Jun  3 13:42:07 UTC 2011
Robert,
the shell via telnetd uses the RTEMS pseudo-tty package, so you may
adapt the SpaceWire transport layer using PTTY again.
If it is feasible to use the telnetd as a starting point, I cant tell,
because I know very little about SpaceWire.
wkr,
Thomas.
Am 03.06.2011 15:36, schrieb Robert S. Grimes:
> Hi,
> I am hoping to run the RTEMS shell over a SpaceWire port, as I won't
> have a serial port available in the deployed system.  Out of the box,
> the shell can use the console or the telnetd; what is the best way to
> add a third option?
> For those that don't know, SpaceWire is packet-based, so it seems that
> variant of telnetd that uses SpaceWire packets might be the way to go -
> does that make sense?
> What would be the best way to begin?  Any suggestions welcome!
> Thanks.
> rtems-users mailing list
> rtems-users at rtems.org
Embedded Brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
