Fwd: [Milkymist-devel] [PATCH] imfs: give a default value to	st_blksize
    Sebastien Bourdeauducq
    sebastien at milkymist.org
    Fri Jun  3 19:18:35 UTC 2011
On Fri, 2011-06-03 at 20:28 +0200, Joel Sherrill wrote:
> The block size of the IMFS is strictly up to the user within some power of 2 restrictions.
There is nothing else setting st_blksize in IMFS_stat:
http://www.rtems.com/cvsweb/cvsweb.cgi/rtems/cpukit/libfs/src/imfs/imfs_stat.c?rev=1.14;content-type=text%2Fplain
Should it be set to CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK instead of
the hardcoded 1024?
S.
