Fwd: [Milkymist-devel] [PATCH] imfs: give a default value to	st_blksize
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Sat Jun  4 04:55:41 UTC 2011
No. That's the user visible item to set. It should be assigned to a variable in confdefs.h. You want the variable.  This CONFIGURE_xxx value is only visible with the user value in the file where the user instances the configuration. This is the line.
    int imfs_rq_memfile_bytes_per_block = CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK;
So you want that variable.
FWIW  I actually managed to ssh to oar, grep, and copy that from my phone. :)
--joel
Chris Johns <chrisj at rtems.org> wrote:
>On 4/06/11 5:18 AM, Sebastien Bourdeauducq wrote:
>> On Fri, 2011-06-03 at 20:28 +0200, Joel Sherrill wrote:
>>> The block size of the IMFS is strictly up to the user within some power of 2 restrictions.
>> There is nothing else setting st_blksize in IMFS_stat:
>> http://www.rtems.com/cvsweb/cvsweb.cgi/rtems/cpukit/libfs/src/imfs/imfs_stat.c?rev=1.14;content-type=text%2Fplain
>> Should it be set to CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK instead of
>> the hardcoded 1024?
>Yes. This change should be fine.
>Chris
