Fwd: [Milkymist-devel] [PATCH] imfs: give a default value to	st_blksize
    Sebastien Bourdeauducq
    sebastien at milkymist.org
    Sat Jun  4 17:19:59 UTC 2011
On Sat, 2011-06-04 at 06:55 +0200, Joel Sherrill wrote:
>     int imfs_rq_memfile_bytes_per_block = CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK;
> So you want that variable.
I'm using buf->st_blksize = imfs_rq_memfile_bytes_per_block in my tree
and it works (i.e. the bugs that I had with the mv shell command are
gone). Can you apply the change upstream too?
Thanks,
Sébastien
