Fwd: [Milkymist-devel] [PATCH] imfs: give a default value to st_blksize
Joel Sherrill
joel.sherrill at OARcorp.com
Sat Jun 4 17:30:24 UTC 2011
Could you please file a PR on this? It really needs to get fixed in the release branches as well and we need a PR to do it.
I won't personally be able to commit until I get home though.
--joel
Sebastien Bourdeauducq <sebastien at milkymist.org> wrote:
>On Sat, 2011-06-04 at 06:55 +0200, Joel Sherrill wrote:
>> int imfs_rq_memfile_bytes_per_block = CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK;
>> So you want that variable.
>I'm using buf->st_blksize = imfs_rq_memfile_bytes_per_block in my tree
>and it works (i.e. the bugs that I had with the mv shell command are
>gone). Can you apply the change upstream too?
>Thanks,
>Sébastien
