still problem with ARM and  Unlimited Task Test
    Joachim Rahn
    Joachim.Rahn at helmholtz-berlin.de
    Wed Jun 15 14:31:29 UTC 2011
On 15.06.2011 15:44, Joel Sherrill wrote:
> On 06/15/2011 08:08 AM, Joachim Rahn wrote:
>> Hi Joel,
>> hope I don't bother you too much...
>> Now I found some time beside my main work to come back to my problem with the
>> failing Unlimited Task Test on our ARM board.
>> Any advice regarding the following would be welcome!!!
>> In fact our problem has nothing directly to do with the update between RTEMS 4.9.3 and 4.9.5 !
>> BTW: We now use the shared code in the BSP tree to initialize the workspace (BSP_BOOTCARD_HANDLES_RAM_ALLOCATION = TRUE)
>>       and we compile every thing with all RTEMS and HEAP debugging on.
>> We now have a setup with RTEMS 4.9.3 on a AT91SAM9263-EK evaluation board from Atmel which reproduces
>> our data abort fault.
>> The problem seems to be that under some circumstances the routine
>>          _RTEMS_task_Switch_extension(Thread_Control *executing, Thread_Control *heir)
>> will be called with a reference to an executing task (*executing) after
>> the routine
>>          _RTEMS_task_Delete_extension(Thread_Control *executing, Thread_Control *heir)
>> has already deleted the certain task and a following call sequence to
>>          _RTEMS_tasks_Free
>>          _Objects_Free
>>          _Objects_Shrink_information
>> ends up in a call to
>>          _Heap_Free(Heap_Control *the_heap, void *starting_address)
>> which frees the memory used by this certain Thread_Control struct of that task and overwites the
>> pointer "executing->task_variables" (which now should be NULL) with some heap information.
>> Because "executing->task_variables" now is corrupted the call to _RTEMS_task_Switch_extension
>> leads to a data_abort.
>> GDB output of the concerning call sequences using the gdb up command looks like:
>> GDB stack walk: _RTEMS_tasks_Delete_extension (executing=0x23fca500, deleted=0x23fca500)
>>                  _User_extensions_Thread_delete (the_thread=0x23fca500)
>>                  _Thread_Close (information=0x2002fd98, the_thread=0x23fca500)
>>                   rtems_task_delete (id=0)
>>                   test_task (my_number=8)
>>                  _Thread_Handler ()
>>                  _Objects_API_maximum_class (api=536959452)
>> GDB stack walk: _Heap_Free (the_heap=0x2002fe4c, starting_address=0x23fca0a0)
>>                  _Workspace_Free (block=0x23fca0a0)
>>                  _Objects_Shrink_information (information=0x2002fd98)
>>                  _Objects_Free (information=0x2002fd98, the_object=0x23fca500)
>>                  _RTEMS_tasks_Free (the_task=0x23fca500)
>>                  _Thread_Handler ()
>> NOW "executing->task_variables" IS CORRUPTED !!!!!
>> GDB stack walk: _RTEMS_tasks_Switch_extension (executing=0x23fca500, heir=0x23fac488)
>>                  _User_extensions_Thread_switch (executing=0x23fca500, heir=0x23fac488)
>>                  _Thread_Dispatch ()
>>                  _Thread_Enable_dispatch ()
>>                  _Thread_Handler ()
>> By chance the pointer to "next_block->prev_size" in the call to _Heap_Free has the same location as
>> "executing->task_variables" in the concerning Thread_Control struct and therefore _RTEMS_task_Switch_extension
>> tries to access a bad memory location which of course leads to a data_abort.
>> May be under other circumstances one will never stumble upon this?
> The memory has indeed been freed and is not supposed to be used.
> In fact, executing->task_variables should be NULL.  I see it set
> to NULL in _RTEMS_tasks_Delete_extension.  Can you verify that?
YES: I've verified it, executing->task_variables is set to NULL by _RTEMS_tasks_Delete_extension!
BUT: after _Heap_Free has been called executing->task_variables is altered
     because at the former location of executing->task_variables now the _Heap_Free routine
     expects next_block->prev_size and alters it to 3096 or 0xCE0.
     The following call to _RTEMS_tasks_Switch_extension checks if executing->task_variables is NULL
     but it's now 0xCE0 resp. NOT NULL.
<...snip... cpukit/rtems/src/tasks.c >
void _RTEMS_tasks_Switch_extension(
  rtems_task_variable_t *tvp;
   *  Per Task Variables
  tvp = executing->task_variables;
  while (tvp) {
    tvp->tval = *tvp->ptr;
<...snip...>
     therefore the check of NULL fails and the last line of code in the snippet results into a data abort...
> I think the extensions should ensure they are not operating on
> a deleted task.  The extensions pointers and task variable
> pointer should be NULL at this point.  Worst case, they can
> check the state of executing and if is has STATES_DORMANT set,
> then don't do anything for executing.
> I checked the 4.9 source for this part of the Classic API extensions.
> They are setting things to NULL and the switch extension is checking
> it.
> FWIW there is a PR outstanding spotted on SMP work where the
> thread stack is freed and potentially reallocated for some other
> purpose before the delete(SELF) task is finished switching out.
> I don't think that's happening here but it is worth mentioning.
>> BTW: When I change (as a test) the definition of CPU_HEAP_ALIGNMENT in
>>       ..../rtems/cpukit/score/cpu/arm/rtems/score/cpu.h
>>       from CPU_ALIGNMENT (which is 4) to something larger than CPU_ALIGNMENT,
>>       the unlimited test works fine.
>> Any idea or advice ...?
>> Regards,
>> Joachim
>> On 01.03.2011 17:09, Joel Sherrill wrote:
>>> On 03/01/2011 07:48 AM, Joachim Rahn wrote:
>>>> Hi all,
>>>> after updating from rtems-4.9.3 to rtems-4.9.5 the "Unlimited Task Test" on my
>>>> ARM cpu at91sam9263 fails with a message like...
>>>> [...skip...]
>>>> task 19 ending.
>>>> task 20 ending.
>>>> task 21 ending.
>>>> task 7 ending.
>>>> task 8 ending.
>>>> INSN_LDR
>>>> data_abort at address 0x20018CD8, instruction: 0xE5932000,   spsr = 0x20000013
>>>> active thread thread 0x0A010001
>>>> Previous sp=0x200629A8 lr=0x200135E0 and actual cpsr=60000097
>>>>    0x20038E30 0x20056EA8 0x0000117C 0x200629E0 0x200629C4 0x200135E0
>>>>    0x20018CB8 0x20038E30 0x20056EA8 0x20026EC0 0x20026EC0 0x20062A18
>>>>    0x200629E4 0x20010100 0x200135AC 0x00000000 0x00000000 0x00000000
>>>>    0x00000000 0x20056EA8 0x20038E30 0x60000013 0x600000D3 0x00000000
>>>>    0x00000000 0x20062A28 0x20062A1C 0x2000AE48 0x2000FFF8 0x20062A4C
>>>>    0x20062A2C 0x2000ADA0 0x2000AE24 0x521C9845 0x20056EA8 0x00000000
>>>>    0x00000000 0x2002ACD8 0x20062A64 0x20062A50 0x20000348 0x2000AD28
>>>>    0x00000008 0x00000001 0x20062A84 0x20062A68 0x2001C2D4 0x20000310
>>>> [...skip...]
>>>> which commonly means the cpu tries to access non available memory.
>>>> After removing the bugfix bug1718 the "Unlimited Task Test" works fine.
>>>> (https://www.rtems.org/bugzilla/show_bug.cgi?id=1718)
>>>> *** rtems-4.9.3: ./cpukit/sapi/include/confdefs.h *** unlimited task test works
>>>> [...skip...]
>>>>     #define CONFIGURE_MEMORY_PER_TASK_FOR_POSIX_API \
>>>>       _Configure_From_workspace( \
>>>>         sizeof (POSIX_API_Control) + \
>>>>        (sizeof (void *) * (CONFIGURE_MAXIMUM_POSIX_KEYS)) \
>>>> [...skip...]
>>>> *** rtems-4.9.5: ./cpukit/sapi/include/confdefs.h *** unlimited task test doesn't work
>>>> [...skip...]
>>>>         CONFIGURE_MINIMUM_TASK_STACK_SIZE + \
>>>> [...skip...]
>>>> Any hints respectively does anyone observe the same?
>>> That patch wouldn't directly cause that failure.
>>> The only think I can see is that does change the
>>> amount of workspace reserved up front (by a lot).
>>> Is this a BSP which is in the RTEMS tree?  I am
>>> suspicious that there isn't enough memory for
>>> the workspace/heap and the BSP initialization
>>> isn't recognizing this.  Eventually the task stacks,
>>> heap, etc all collide, there is corruption and you crash.
>>> So we would need to know the following:
>>> + address of end of BSS
>>> + start of memory for heap and length
>>> + start of memory for RTEMS workspace and length.
>>> + amount of RAM
>>> Assuming that the workspace/heap are from end of
>>> BSS to the end of RAM.
>>>> Cheers
>>>> Joachim
>>>> ________________________________
>>>> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
>>>> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V
>>>> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
>>>> Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
>>>> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
>>>> Postadresse:
>>>> Hahn-Meitner-Platz 1
>>>> D-14109 Berlin
>>>> http://www.helmholtz-berlin.de
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
>> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
>> Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
>> Postadresse:
>> D-14109 Berlin
Postadresse:
D-14109 Berlin
