still problem with ARM and  Unlimited Task Test
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Wed Jun 15 16:07:58 UTC 2011
Chris.. cc'ing you on this due to the unlimited nature.
Sebastian.. cc'ing you to conform me on heap side-effect.
On 06/15/2011 09:31 AM, Joachim Rahn wrote:
> On 15.06.2011 15:44, Joel Sherrill wrote:
>> On 06/15/2011 08:08 AM, Joachim Rahn wrote:
>>> Hi Joel,
>>> hope I don't bother you too much...
>>> Now I found some time beside my main work to come back to my problem with the
>>> failing Unlimited Task Test on our ARM board.
>>> Any advice regarding the following would be welcome!!!
>>> In fact our problem has nothing directly to do with the update between RTEMS 4.9.3 and 4.9.5 !
>>> BTW: We now use the shared code in the BSP tree to initialize the workspace (BSP_BOOTCARD_HANDLES_RAM_ALLOCATION = TRUE)
>>>        and we compile every thing with all RTEMS and HEAP debugging on.
>>> We now have a setup with RTEMS 4.9.3 on a AT91SAM9263-EK evaluation board from Atmel which reproduces
>>> our data abort fault.
>>> The problem seems to be that under some circumstances the routine
>>>           _RTEMS_task_Switch_extension(Thread_Control *executing, Thread_Control *heir)
>>> will be called with a reference to an executing task (*executing) after
>>> the routine
>>>           _RTEMS_task_Delete_extension(Thread_Control *executing, Thread_Control *heir)
>>> has already deleted the certain task and a following call sequence to
>>>           _RTEMS_tasks_Free
>>>           _Objects_Free
>>>           _Objects_Shrink_information
>>> ends up in a call to
>>>           _Heap_Free(Heap_Control *the_heap, void *starting_address)
>>> which frees the memory used by this certain Thread_Control struct of that task and overwites the
>>> pointer "executing->task_variables" (which now should be NULL) with some heap information.
>>> Because "executing->task_variables" now is corrupted the call to _RTEMS_task_Switch_extension
>>> leads to a data_abort.
>>> GDB output of the concerning call sequences using the gdb up command looks like:
>>> GDB stack walk: _RTEMS_tasks_Delete_extension (executing=0x23fca500, deleted=0x23fca500)
>>>                   _User_extensions_Thread_delete (the_thread=0x23fca500)
>>>                   _Thread_Close (information=0x2002fd98, the_thread=0x23fca500)
>>>                    rtems_task_delete (id=0)
>>>                    test_task (my_number=8)
>>>                   _Thread_Handler ()
>>>                   _Objects_API_maximum_class (api=536959452)
>>> GDB stack walk: _Heap_Free (the_heap=0x2002fe4c, starting_address=0x23fca0a0)
>>>                   _Workspace_Free (block=0x23fca0a0)
>>>                   _Objects_Shrink_information (information=0x2002fd98)
>>>                   _Objects_Free (information=0x2002fd98, the_object=0x23fca500)
>>>                   _RTEMS_tasks_Free (the_task=0x23fca500)
>>>                   _Thread_Handler ()
>>> NOW "executing->task_variables" IS CORRUPTED !!!!!
>>> GDB stack walk: _RTEMS_tasks_Switch_extension (executing=0x23fca500, heir=0x23fac488)
>>>                   _User_extensions_Thread_switch (executing=0x23fca500, heir=0x23fac488)
>>>                   _Thread_Dispatch ()
>>>                   _Thread_Enable_dispatch ()
>>>                   _Thread_Handler ()
>>> By chance the pointer to "next_block->prev_size" in the call to _Heap_Free has the same location as
>>> "executing->task_variables" in the concerning Thread_Control struct and therefore _RTEMS_task_Switch_extension
>>> tries to access a bad memory location which of course leads to a data_abort.
>>> May be under other circumstances one will never stumble upon this?
>> The memory has indeed been freed and is not supposed to be used.
>> In fact, executing->task_variables should be NULL.  I see it set
>> to NULL in _RTEMS_tasks_Delete_extension.  Can you verify that?
> YES: I've verified it, executing->task_variables is set to NULL by _RTEMS_tasks_Delete_extension!
> BUT: after _Heap_Free has been called executing->task_variables is altered
>       because at the former location of executing->task_variables now the _Heap_Free routine
>       expects next_block->prev_size and alters it to 3096 or 0xCE0.
>       The following call to _RTEMS_tasks_Switch_extension checks if executing->task_variables is NULL
>       but it's now 0xCE0 resp. NOT NULL.
I hope this is reproducible enough to verify this.
Can you set a watchpoint after the memory location that is set to
NULL and then overwritten?  I don't see any reasonable way for the
heap to write to this address.   task_variables is the last field
in the Thread_Control block.  TCBs are pre-allocated and never
freed back to the heap except for "shrinking" in the unlimited
object case.
What I suspect is happening, is that when the task in question
is deleted, _Objects_Shrink_information is being called and freeing
a "chunk" of unused TCBs.  If the array of TCBS EXACTLY meets the
alignment, then when it is freed, there will be no pad at the end
of it since it is a multiple of 4 (not sure what else).  The last four
bytes must be getting overwritten when the memory is freed.
Chris .. Sebastian.. does that seem possible?
One way to check this is to add a few unused fields to the end
of the Thread_Control, set them to 0 when initialized and
check that they are overwritten.
Permanent fixes include:
+ checking for dormant start in switch extension
+ moving something large-ish like Start down to the
end of the TCB structure.  Then when freed like this, it
won't matter since it has already been used and won't
be referenced.
If we decide the second alternative is better, then there
needs to be some documentation.
If the first is implemented, then unfortunately, I think
it needs to be in every switch extension.
> <...snip... cpukit/rtems/src/tasks.c>
> void _RTEMS_tasks_Switch_extension(
>    rtems_task_variable_t *tvp;
>     *  Per Task Variables
>    tvp = executing->task_variables;
>    while (tvp) {
>      tvp->tval = *tvp->ptr;
> <...snip...>
>       therefore the check of NULL fails and the last line of code in the snippet results into a data abort...
>> I think the extensions should ensure they are not operating on
>> a deleted task.  The extensions pointers and task variable
>> pointer should be NULL at this point.  Worst case, they can
>> check the state of executing and if is has STATES_DORMANT set,
>> then don't do anything for executing.
>> I checked the 4.9 source for this part of the Classic API extensions.
>> They are setting things to NULL and the switch extension is checking
>> it.
>> FWIW there is a PR outstanding spotted on SMP work where the
>> thread stack is freed and potentially reallocated for some other
>> purpose before the delete(SELF) task is finished switching out.
>> I don't think that's happening here but it is worth mentioning.
>>> BTW: When I change (as a test) the definition of CPU_HEAP_ALIGNMENT in
>>>        ..../rtems/cpukit/score/cpu/arm/rtems/score/cpu.h
>>>        from CPU_ALIGNMENT (which is 4) to something larger than CPU_ALIGNMENT,
>>>        the unlimited test works fine.
>>> Any idea or advice ...?
>>> Regards,
>>> Joachim
>>> On 01.03.2011 17:09, Joel Sherrill wrote:
>>>> On 03/01/2011 07:48 AM, Joachim Rahn wrote:
>>>>> Hi all,
>>>>> after updating from rtems-4.9.3 to rtems-4.9.5 the "Unlimited Task Test" on my
>>>>> ARM cpu at91sam9263 fails with a message like...
>>>>> [...skip...]
>>>>> task 19 ending.
>>>>> task 20 ending.
>>>>> task 21 ending.
>>>>> task 7 ending.
>>>>> task 8 ending.
>>>>> INSN_LDR
>>>>> data_abort at address 0x20018CD8, instruction: 0xE5932000,   spsr = 0x20000013
>>>>> active thread thread 0x0A010001
>>>>> Previous sp=0x200629A8 lr=0x200135E0 and actual cpsr=60000097
>>>>>     0x20038E30 0x20056EA8 0x0000117C 0x200629E0 0x200629C4 0x200135E0
>>>>>     0x20018CB8 0x20038E30 0x20056EA8 0x20026EC0 0x20026EC0 0x20062A18
>>>>>     0x200629E4 0x20010100 0x200135AC 0x00000000 0x00000000 0x00000000
>>>>>     0x00000000 0x20056EA8 0x20038E30 0x60000013 0x600000D3 0x00000000
>>>>>     0x00000000 0x20062A28 0x20062A1C 0x2000AE48 0x2000FFF8 0x20062A4C
>>>>>     0x20062A2C 0x2000ADA0 0x2000AE24 0x521C9845 0x20056EA8 0x00000000
>>>>>     0x00000000 0x2002ACD8 0x20062A64 0x20062A50 0x20000348 0x2000AD28
>>>>>     0x00000008 0x00000001 0x20062A84 0x20062A68 0x2001C2D4 0x20000310
>>>>> [...skip...]
>>>>> which commonly means the cpu tries to access non available memory.
>>>>> After removing the bugfix bug1718 the "Unlimited Task Test" works fine.
>>>>> (https://www.rtems.org/bugzilla/show_bug.cgi?id=1718)
>>>>> *** rtems-4.9.3: ./cpukit/sapi/include/confdefs.h *** unlimited task test works
>>>>> [...skip...]
>>>>>      #define CONFIGURE_MEMORY_PER_TASK_FOR_POSIX_API \
>>>>>        _Configure_From_workspace( \
>>>>>          sizeof (POSIX_API_Control) + \
>>>>>         (sizeof (void *) * (CONFIGURE_MAXIMUM_POSIX_KEYS)) \
>>>>> [...skip...]
>>>>> *** rtems-4.9.5: ./cpukit/sapi/include/confdefs.h *** unlimited task test doesn't work
>>>>> [...skip...]
>>>>>          CONFIGURE_MINIMUM_TASK_STACK_SIZE + \
>>>>> [...skip...]
>>>>> Any hints respectively does anyone observe the same?
>>>> That patch wouldn't directly cause that failure.
>>>> The only think I can see is that does change the
>>>> amount of workspace reserved up front (by a lot).
>>>> Is this a BSP which is in the RTEMS tree?  I am
>>>> suspicious that there isn't enough memory for
>>>> the workspace/heap and the BSP initialization
>>>> isn't recognizing this.  Eventually the task stacks,
>>>> heap, etc all collide, there is corruption and you crash.
>>>> So we would need to know the following:
>>>> + address of end of BSS
>>>> + start of memory for heap and length
>>>> + start of memory for RTEMS workspace and length.
>>>> + amount of RAM
>>>> Assuming that the workspace/heap are from end of
>>>> BSS to the end of RAM.
>>>>> Cheers
>>>>> Joachim
>>>>> ________________________________
>>>>> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
>>>>> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V
>>>>> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
>>>>> Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
>>>>> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
>>>>> Postadresse:
>>>>> Hahn-Meitner-Platz 1
>>>>> D-14109 Berlin
>>>>> http://www.helmholtz-berlin.de
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.org
>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
>>> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
>>> Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
>>> Postadresse:
>>> D-14109 Berlin
> Postadresse:
> D-14109 Berlin
Joel Sherrill, Ph.D.             Director of Research&  Development
