ARM - after update from rtems4.9.3 to rtems-4.9.5 Unlimited Task Test fails
Joachim Rahn
Joachim.Rahn at helmholtz-berlin.de
Tue Mar 1 13:48:45 UTC 2011
Hi all,
after updating from rtems-4.9.3 to rtems-4.9.5 the "Unlimited Task Test" on my
ARM cpu at91sam9263 fails with a message like...
[...skip...]
task 19 ending.
task 20 ending.
task 21 ending.
task 7 ending.
task 8 ending.
INSN_LDR
data_abort at address 0x20018CD8, instruction: 0xE5932000, spsr = 0x20000013
active thread thread 0x0A010001
Previous sp=0x200629A8 lr=0x200135E0 and actual cpsr=60000097
0x20038E30 0x20056EA8 0x0000117C 0x200629E0 0x200629C4 0x200135E0
0x20018CB8 0x20038E30 0x20056EA8 0x20026EC0 0x20026EC0 0x20062A18
0x200629E4 0x20010100 0x200135AC 0x00000000 0x00000000 0x00000000
0x00000000 0x20056EA8 0x20038E30 0x60000013 0x600000D3 0x00000000
0x00000000 0x20062A28 0x20062A1C 0x2000AE48 0x2000FFF8 0x20062A4C
0x20062A2C 0x2000ADA0 0x2000AE24 0x521C9845 0x20056EA8 0x00000000
0x00000000 0x2002ACD8 0x20062A64 0x20062A50 0x20000348 0x2000AD28
0x00000008 0x00000001 0x20062A84 0x20062A68 0x2001C2D4 0x20000310
[...skip...]
which commonly means the cpu tries to access non available memory.
After removing the bugfix bug1718 the "Unlimited Task Test" works fine.
(https://www.rtems.org/bugzilla/show_bug.cgi?id=1718)
*** rtems-4.9.3: ./cpukit/sapi/include/confdefs.h *** unlimited task test works
[...skip...]
#define CONFIGURE_MEMORY_PER_TASK_FOR_POSIX_API \
_Configure_From_workspace( \
sizeof (POSIX_API_Control) + \
(sizeof (void *) * (CONFIGURE_MAXIMUM_POSIX_KEYS)) \
[...skip...]
*** rtems-4.9.5: ./cpukit/sapi/include/confdefs.h *** unlimited task test doesn't work
[...skip...]
CONFIGURE_MINIMUM_TASK_STACK_SIZE + \
[...skip...]
Any hints respectively does anyone observe the same?
Cheers
Joachim
________________________________
Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Sitz Berlin, AG Charlottenburg, 89 HRB 5583
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
http://www.helmholtz-berlin.de
