ARM - after update from rtems4.9.3 to rtems-4.9.5 Unlimited Task Test fails
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Mar 1 16:09:16 UTC 2011
On 03/01/2011 07:48 AM, Joachim Rahn wrote:
> Hi all,
> after updating from rtems-4.9.3 to rtems-4.9.5 the "Unlimited Task Test" on my
> ARM cpu at91sam9263 fails with a message like...
> [...skip...]
> task 19 ending.
> task 20 ending.
> task 21 ending.
> task 7 ending.
> task 8 ending.
> INSN_LDR
> data_abort at address 0x20018CD8, instruction: 0xE5932000, spsr = 0x20000013
> active thread thread 0x0A010001
> Previous sp=0x200629A8 lr=0x200135E0 and actual cpsr=60000097
> 0x20038E30 0x20056EA8 0x0000117C 0x200629E0 0x200629C4 0x200135E0
> 0x20018CB8 0x20038E30 0x20056EA8 0x20026EC0 0x20026EC0 0x20062A18
> 0x200629E4 0x20010100 0x200135AC 0x00000000 0x00000000 0x00000000
> 0x00000000 0x20056EA8 0x20038E30 0x60000013 0x600000D3 0x00000000
> 0x00000000 0x20062A28 0x20062A1C 0x2000AE48 0x2000FFF8 0x20062A4C
> 0x20062A2C 0x2000ADA0 0x2000AE24 0x521C9845 0x20056EA8 0x00000000
> 0x00000000 0x2002ACD8 0x20062A64 0x20062A50 0x20000348 0x2000AD28
> 0x00000008 0x00000001 0x20062A84 0x20062A68 0x2001C2D4 0x20000310
> [...skip...]
> which commonly means the cpu tries to access non available memory.
> After removing the bugfix bug1718 the "Unlimited Task Test" works fine.
> (https://www.rtems.org/bugzilla/show_bug.cgi?id=1718)
> *** rtems-4.9.3: ./cpukit/sapi/include/confdefs.h *** unlimited task test works
> [...skip...]
> #define CONFIGURE_MEMORY_PER_TASK_FOR_POSIX_API \
> _Configure_From_workspace( \
> sizeof (POSIX_API_Control) + \
> (sizeof (void *) * (CONFIGURE_MAXIMUM_POSIX_KEYS)) \
> [...skip...]
> *** rtems-4.9.5: ./cpukit/sapi/include/confdefs.h *** unlimited task test doesn't work
> [...skip...]
> CONFIGURE_MINIMUM_TASK_STACK_SIZE + \
> [...skip...]
> Any hints respectively does anyone observe the same?
That patch wouldn't directly cause that failure.
The only think I can see is that does change the
amount of workspace reserved up front (by a lot).
Is this a BSP which is in the RTEMS tree? I am
suspicious that there isn't enough memory for
the workspace/heap and the BSP initialization
isn't recognizing this. Eventually the task stacks,
heap, etc all collide, there is corruption and you crash.
So we would need to know the following:
+ address of end of BSS
+ start of memory for heap and length
+ start of memory for RTEMS workspace and length.
+ amount of RAM
Assuming that the workspace/heap are from end of
BSS to the end of RAM.
> Cheers
> Joachim
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
> Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D. Director of Research& Development
