Problem building RTEMS4.10
Mon Mar 7 14:13:04 UTC 2011
On 03/07/2011 06:39 AM, Sebastian Huber wrote:
> On 03/07/2011 10:20 AM, Shah, Viral wrote:
>> *ction). *Has anyone faced similar problem? Can someone tell me what
>> causes to give this error?
> This is a bug in the BSP.  We will have to investigate this further.
If you configure without the --disable-posix,
it will get around this.
Also you can use --enable-rtemsbsp=XXX to configure
a specific BSP
Joel Sherrill, Ph.D.             Director of Research&  Development
