Problem building RTEMS4.10
Shah, Viral viral.ashah at patni.com
Tue Mar 8 06:47:25 UTC 2011
Hi,
As a work around, we commented below code in "bspstart.c" available at below location and the "make all" was successful.
\rtems-4.10.0\c\src\lib\libbsp\m68k\genmcf548x\startup
/* Switch on FPU in CACR shadow register if necessary */
  if ((Configuration_POSIX_API.number_of_initialization_threads > 0) ||
      ((Configuration_RTEMS_API.number_of_initialization_tasks > 0) &&
       (Configuration_RTEMS_API.User_initialization_tasks_table
        ->attribute_set & RTEMS_FLOATING_POINT) != 0)
    _CPU_cacr_shadow &= ~MCF548X_CACR_DF;
Thanks & Regards,
Viral Shah
Specialist(Software) - Product Engineering Services,
Patni Computer Systems Ltd,
IT1/IT2 Patni Knowledge Park (PKP),
Block C, 2nd Floor, Wing A (C2A),
Thane Belapur Road, Airoli,
Navi Mumbai 400 708.
Tel: +91 22 3917 2000 Ext 4203
Tel(Direct): +91 22 3917 4203
Patni Link Line: 9-625-4403
-----Original Message-----
From: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] On Behalf Of rtems-users-request at rtems.org
Sent: Monday, March 07, 2011 11:30 PM
To: rtems-users at rtems.org
Subject: rtems-users Digest, Vol 54, Issue 9
Send rtems-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        http://www.rtems.org/mailman/listinfo/rtems-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        rtems-users-owner at rtems.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of rtems-users digest..."
Today's Topics:
   1. Re: rtems application tutorial (Luc ANTOLINOS)
   2. CPP setting in make/compilers/gcc-target-default.cfg has
      -Wp,$$? (Peter Dufault)
   3. Re: gdb+qemu+rtems: Problem #2 in offset computation
      (Joel Sherrill)
   4. Re: Problem building RTEMS4.10 (Sebastian Huber)
   5. Re: CPP setting in make/compilers/gcc-target-default.cfg has
      -Wp,$$? (Ralf Corsepius)
   6. Re: CPP setting in make/compilers/gcc-target-default.cfg has
   7. Re: Problem building RTEMS4.10 (Joel Sherrill)
Message: 1
Date: Mon, 7 Mar 2011 11:13:20 +0100
To: Domenico Di Leo <domenico.dileo at unina.it>
Cc: rtems-users at rtems.com
Subject: Re: rtems application tutorial
Message-ID:
        <AANLkTimaS4sQG114wWBUmcrrv6s2s0kxZN4Htwk2HbmD at mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
On 7 March 2011 09:03, Domenico Di Leo <domenico.dileo at unina.it> wrote:
> Hi,
> can you point me out any tutorial on how to write and execute an application
> from the scratch for RTEMS.
> I already checked the ?Application C user guide, it is a good reference, but
> it doesn't
> help me to understand how to compile the application (what compiler should I
> use? ?is there any specific rule for the Makefile?)
http://www.rtems.org/ftp/pub/rtems/4.10.0/examples-v2-4.10.0.tar.bz2
You will find a simple hello world and a simple Makefile. Not a
tutorial but enough to understand all you need.
But before to launch executables, you have to determine on which kind
of target you want to run, etc. Compilers and BSP are target
specifics.
Luc
Message: 2
Date: Mon, 7 Mar 2011 06:57:28 -0500
To: "rtems-users at rtems.org List" <rtems-users at rtems.org>
Subject: CPP setting in make/compilers/gcc-target-default.cfg has
        -Wp,$$?
Message-ID: <19706997-DA38-4AEC-959C-AD0D7FFB4000 at hda.com>
Content-Type: text/plain; charset=us-ascii
With this:
# CPP command to write file to standard output
CPP=$(CC) -E -w -Wp,-$$
I'm having problems in a configure script:
configure:4305: powerpc-rtems4.11-gcc -E -w -Wp,-$  conftest.c
cc1: error: unrecognized command line option "-$"
Anyone know what's up?
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
Message: 3
Date: Mon, 7 Mar 2011 06:14:38 -0600
To: Domenico Di Leo <domenico.dileo at unina.it>, "rtems-users at rtems.com"
        <rtems-users at rtems.com>
Subject: Re: gdb+qemu+rtems: Problem #2 in offset computation
Message-ID: <0l61totmavtg92xlwtbiogyp.1299499833786 at email.android.com>
Content-Type: text/plain; charset="utf-8"
There are (were) five reasons the timer calibation could fail on pc386. It did appear to happen in qemu and not on real hardware and in qemu inside a vm more than just qemu. It is something to do with the simulated timer jumping.  I doubt changing the amount of memory helps. It is rather random. Run again and it may not happen.
FWIW I committed a fix to the head where if it hits this situation, it will retry five times before locking up. Should help. Maybe I should apply this to the release branches.
--joel
>Hi
>I have experienced the same problem.
>My solution was really simple, since I started RTMES with qemu (on a
>Fedora virtual machine)
>with the command qemu -m 128  -boot a ...
>I removed the "m" flag -> qemu -boot a ...  and it worked :)
>Hope this helps other users.
>D.
>Domenico Di Leo, PhD student, Universit? degli Studi di Napoli Federico II
>Ph:     +39 081 676770
>Fax:    +39 081 676574
>Web: http://wpage.unina.it/domenico.dileo (WP)
>_______________________________________________
Message: 4
Date: Mon, 07 Mar 2011 13:39:57 +0100
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Subject: Re: Problem building RTEMS4.10
Message-ID: <4D74D21D.5080608 at embedded-brains.de>
On 03/07/2011 10:20 AM, Shah, Viral wrote:
> *ction). *Has anyone faced similar problem? Can someone tell me what
> causes to give this error?
This is a bug in the BSP.  We will have to investigate this further.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
Diese Nachricht ist keine gesch?ftliche Mitteilung im Sinne des EHUG.
Message: 5
Date: Mon, 07 Mar 2011 13:44:38 +0100
To: Peter Dufault <dufault at hda.com>
Cc: "rtems-users at rtems.org List" <rtems-users at rtems.org>
Subject: Re: CPP setting in make/compilers/gcc-target-default.cfg has
        -Wp,$$?
Message-ID: <4D74D336.30202 at rtems.org>
Content-Type: text/plain; charset=UTF-8; format=flowed
On 03/07/2011 12:57 PM, Peter Dufault wrote:
> With this:
gcc-target-default.cfg is junk. Don't use it.
Ralf
Message: 6
Date: Mon, 7 Mar 2011 09:04:18 -0500
To: Ralf Corsepius <ralf.corsepius at rtems.org>
        -Wp,$$?
Message-ID: <727F0EF3-948D-4E8E-BDB3-D4766438497A at hda.com>
It's included by leaf.cfg which is included in the demos, unless I'm very confused.
In a network-demo Makefile:
include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
include $(RTEMS_CUSTOM)
include $(PROJECT_ROOT)/make/leaf.cfg
In leaf.cfg:
# Pull in the desired "target" compiler
# Programs built on the host use automake generated rules.
# This will not change $(ARCH) -- binaries will still be place as per target
include ${CONFIG.CC}
Adding an echo to the network-demo Makefile:
[dufault at finny12 rtems_main]$ make echo_config_cc
CONFIG.CC=/opt/rtems-4.11/make/compilers/gcc-target-default.cfg
Peter
Peter Dufault
Message: 7
Date: Mon, 7 Mar 2011 08:13:04 -0600
To: Sebastian Huber <sebastian.huber at embedded-brains.de>
Cc: "rtems-users at rtems.org" <rtems-users at rtems.org>
Message-ID: <4D74E7F0.1020702 at oarcorp.com>
Content-Type: text/plain; charset="ISO-8859-1"; format=flowed
If you configure without the --disable-posix,
it will get around this.
Also you can use --enable-rtemsbsp=XXX to configure
a specific BSP
Joel Sherrill, Ph.D.             Director of Research&  Development
End of rtems-users Digest, Vol 54, Issue 9
Information contained and transmitted by this e-mail is confidential and proprietary to Patni Computer Systems Ltd and its affiliates (hitherto referred as Patni Computers) and is intended for use only by the recipient. If you are not the intended recipient , you are hereby notified that any dissemination, distribution,  copying or use of this e-mail is strictly prohibited and you are requested to delete this e-mail immediately and notify the originator or netadmin at patni.com. Patni Computers does not enter into any agreement with any party by e-mail. Any views expressed by an individual do not necessarily reflect the view of Patni Computers. Patni Computers is not responsible for the consequences of any actions taken on the basis of information provided, through this email. The contents of an attachment to this e-mail may contain software viruses, which could damage your own computer system. While Patni Computers has taken every reasonable precaution to minimise this risk, we cannot accept liability for any damage which you sustain as a result of software viruses. You should carry out your own virus checks before opening an attachment. To know more about Patni Computers please visit www.patni.com.
