Problem with LD and Eclipse plug-in
Alejandro Perez coconoway at gmail.com
Wed Mar 23 18:43:49 UTC 2011
Hi all, im a new RTEMS user. I'm trying to build a "hello world" example
from the Eclipse Plug-in with RTEMS 4.10 for the ARM based bsp EDB7312.
My host PC is running Fedora 14 with Autoconf updated to 2.68 and
arm-rtems4.10 toolchain installed from RPM, Eclipse Helio SR2 and REMS
Eclipse Plug-in
I'd downloaded CVS copy, run "bootstrap" and  build the BSP with the command
./configure --target=arm-rtems4.10 --prefix=/home/setron/rtems/arm2303/
--enable-rtems-debug --enable-rtemsbsp="edb7312"
make
make install
Then i create a new proyect in Eclipse with
Base Path : /opt/rtems-4.10
BSP Path :/home/setron/rtems/arm2303/edb7312
then change some stuff from the command line that call gcc neither
arm-rtems4.10-gcc and finaly add include directories
/opt/rtems-4.10/arm-rtems4.10/include
/home/setron/rtems/arm2303/arm-rtems4.10/edb7312/lib/include
Everything goes fine until i try to build the proyect, i get this error
Invoking: RTEMS Linker
/opt/rtems-4.10/bin/arm-rtems4.10-gcc
-L/opt/rtems-4.10/lib/gcc/arm-rtems4.10/4.4.5
-L/home/setron/rtems/arm2303/arm-rtems4.10/lpc32xx_mzx/lib -o"arm98.exe"
./src/arm98.o
/opt/rtems-4.10/lib/gcc/arm-rtems4.10/4.4.5/../../../../arm-rtems4.10/bin/ld:
warning: cannot find entry symbol _start; defaulting to 00008000
./src/arm98.o:(.data+0x0): undefined reference to `rtems_libio_init'
./src/arm98.o:(.data+0x4): undefined reference to `open_dev_console'
./src/arm98.o:(.data+0x8): undefined reference to
`rtems_filesystem_initialize'
./src/arm98.o:(.data+0x1c): undefined reference to
`_Scheduler_priority_Initialize'
./src/arm98.o:(.data+0x20): undefined reference to
`_Scheduler_priority_Schedule'
./src/arm98.o:(.data+0x24): undefined reference to
`_Scheduler_priority_Yield'
./src/arm98.o:(.data+0x28): undefined reference to
`_Scheduler_priority_Block'
./src/arm98.o:(.data+0x2c): undefined reference to
`_Scheduler_priority_Unblock'
./src/arm98.o:(.data+0x30): undefined reference to
`_Scheduler_priority_Allocate'
./src/arm98.o:(.data+0x34): undefined reference to
`_Scheduler_priority_Free'
./src/arm98.o:(.data+0x38): undefined reference to
`_Scheduler_priority_Update'
./src/arm98.o:(.data+0x3c): undefined reference to
`_Scheduler_priority_Enqueue'
./src/arm98.o:(.data+0x40): undefined reference to
`_Scheduler_priority_Enqueue_first'
./src/arm98.o:(.data+0x44): undefined reference to
`_Scheduler_priority_Extract'
./src/arm98.o:(.data+0x64): undefined reference to `bsp_boot_cmdline'
./src/arm98.o:(.data+0x68): undefined reference to `console_initialize'
./src/arm98.o:(.data+0x6c): undefined reference to `console_open'
./src/arm98.o:(.data+0x70): undefined reference to `console_close'
./src/arm98.o:(.data+0x74): undefined reference to `console_read'
./src/arm98.o:(.data+0x78): undefined reference to `console_write'
./src/arm98.o:(.data+0x7c): undefined reference to `console_control'
./src/arm98.o:(.data+0x80): undefined reference to `newlib_create_hook'
./src/arm98.o:(.data+0x8c): undefined reference to `newlib_delete_hook'
./src/arm98.o:(.data+0x118): undefined reference to
`_RTEMS_tasks_Initialize_user_tasks_body'
./src/arm98.o:(.rodata+0x4): undefined reference to `miniIMFS_initialize'
collect2: ld returned 1 exit status
I think that the plug-in is not loading the "linkcmds" file of the BSP....
Any idea how can i solve this?
Thanks.
Alejandro Perez
URL: <http://lists.rtems.org/pipermail/users/attachments/20110323/98af77f0/attachment.html>
