Resurrecting MVME167
Eric Norum
wenorum at lbl.gov
Wed Mar 23 17:46:19 UTC 2011
On Mar 23, 2011, at 10:12 AM, Joel Sherrill wrote:
> Well we just saw ticker run on it. Some default
> settings for the BSP are a bit surprising. I would
> like to hear from the community before changing
> them.
> + Default console is NOT the MBug port. It is
> the second serial port. Does this make sense for
> a default?
> + Ditto for printk port.
> + printk support is disabled by default.
This might be a relic of using the serial port to download an S-record image. Remember this code dates from back in the days when networks weren't ubiquitous.
> + Load address is 0x800000. Isn't this a bit
> high in memory? Usually I recall only seeing
> addresses like 0x10000 or 0x20000 to skip
> MBug RAM usage.
Some folks liked to configure the RAM to be at a location other than 0 to catch NULL pointer dereferences. Apparently the developer of this BSP was one of those folks.
> + Defaults to getting settings from NVRAM
> and ignoring configure overrides. Since our
> NVRAM was trashed, this didn't help matters.
> Any comments on the above? These just don't
> seem consistent with the other BSPs.
> --joel
"It seemed like a good idea at the time"?
The definition of "standard operating procedures" has likely changed over the years.
Eric Norum
wenorum at lbl.gov
