NULL call to _Workspace_Free() via _Objects_Extend_information at startup
Peter Dufault dufault at hda.com
Tue Mar 1 00:09:19 UTC 2011
On Feb 28, 2011, at 6:58 , Joel Sherrill wrote:
> It should be
>   if ( !_Heap_Is_block_in_heap( heap, block ) ) {
>     return false;
> _Heap_Protection_block_check( heap, block );
I haven't found "_Heap_Is_block_in_heap" in my tags yet, however, I see this as a tertiary operation: Block is in heap, block is not in heap, block is NULL, just like malloc() / free():  block == NULL should be silently ignored.  IMHO.
Not that I've written anything that calls _Workspace_Free(), however, I routinely count on free(0) doing nothing and would probably like _Workspace_Free() to do the same thing.
> I am sorry you hit this.  Very good/bad timing. :)
Timing is everything.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
