NULL call to _Workspace_Free() via _Objects_Extend_information at startup
Chris Johns
chrisj at rtems.org
Tue Mar 1 00:16:36 UTC 2011
On 1/03/11 11:09 AM, Peter Dufault wrote:
> I haven't found "_Heap_Is_block_in_heap" in my tags yet, however, I see this as a tertiary operation: Block is in heap, block is not in heap, block is NULL, just like malloc() / free(): block == NULL should be silently ignored. IMHO.
It will be ignored just like 'free'. We will just use the 'in heap call'
to do this. Treating NULL as a special case has meant the bugs where
hidden and if a non-NULL bad pointer is passed in no protection to the
user is provided.
I suspect this shows up on some hardware and not other depending on
hardware traps on various targets. On the sparc simulator I see the
problem as the NULL under rolls to a high address and the MacOS build of
gdb+sim catches the access. Joel does not see it on a Linux gdb+sim from
the RPMs. I do not know why.
> Not that I've written anything that calls _Workspace_Free(), however, I routinely count on free(0) doing nothing and would probably like _Workspace_Free() to do the same thing.
The Object extended information code does count on this working.
Thanks for raising the PR.
