RTEMS coverage
Aitor Viana aitor.viana.sanchez at esa.int
Tue Mar 8 15:12:08 UTC 2011
I ported GCOV to be working with RTMES. There was a post also in this forum
and I sent the GCOV software I had to both the lady posting in the forum and
to the distribution list. Unfortunately the attached got filter by the
distribution list and never saw light.
If you are interested I could send you what I have.
regards,
Aitor
On Tue, Mar 8, 2011 at 9:40 AM, Domenico Di Leo <domenico.dileo at unina.it>wrote:
> I'm interested in analyzing the coverage of RTEMS code, some piece of the
> kernel and some managers.
> I would like to know if there is any (easy) way to do it.
> As far as I know, it is not possible to use GCOV (because there is no
> porting). The first alternative that I found
> is covmerge
> http://bharath-rtems.blogspot.com/2010/05/getting-started-with-coverage-on-rtems.html
> I've tried to use it on RTEMS 4.6 (I have to analyze the coverage over the
> last 4 versions) and
> after running the configure command,  I get the error message "sure to have
> zlib and headers installed"
>  zlib-1.2.5-2.fc14.686 is installed on my fedora 14. Maybe configure is
> looking for an older version.
> Since  I do not want to change the configuration of my Fedora, is there any
> workaround for the configure file?
> Is there another way to know the coverage of managers and internal piece of
> kernel in RTEMS.
> Any help is appreciated.
> Thank you in advance.
> Domenico Di Leo, PhD student, Università degli Studi di Napoli Federico II
> Ph:     +39 081 676770
> Fax:    +39 081 676574
> Web: http://wpage.unina.it/domenico.dileo (WP)
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20110308/82a3fcd2/attachment-0001.html>
