Mutex problem
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Mar 29 13:08:51 UTC 2011
On 03/29/2011 03:39 AM, Leon Pollak wrote:
> I ask the community for a deep pardon - the problem found and, as
> always, is stupid.
OK. You tease us. What was it? :D
My reading of this was that it behaved like it was supposed to. The high
priority task "transferred" the semaphore to a low priority one and
continued to run.
--joel
> On Tuesday March 29 2011, Leon Pollak wrote:
> > Hello, all.
> > I am running 4.8.0 and have some strange situation (below). Are
> there any
> > known problems in this version with mutexes?
> > Two tasks A (prio 2) and B (prio 135) are competing on a resource
> protected
> > by mutex (FIFO mode). I made memory logger, which logs each suspicious
> > point both tasks path.
> > It also logs the value (I k ow the number of the semaphore to be 25):
> > ((Semaphore_Control*)_Semaphore_Information.local_table[25])-
> > >Core_control.mutex.lock
> > What I see is that A enters (lock=1), obtains the mutex (lock=0), starts
> > processing, waits for the I/O and at this point B enters and stands
> waiting
> > for the mutex. lock=0 all the time, which seems correct.
> > Then, A finishes, (lock=0), RELEASES the mutex - lock still is 0!!??
> > Here I supposed, that the token was implicitly passed to task B,
> although
> > it does not run yet.
> > OK, now B continues, releases the semaphore, but lock again is 0. And
> > remains as such forever. The system is succefully blocked and does
> > nothing..:-)
> > When I ask for semaphore state with the help of GDB macros, I see that
> > semaphore is held by task B.
> > Any hint will be highly appreciated.
> Leon
Joel Sherrill, Ph.D. Director of Research& Development
