GSoC 2011 - Lua scripting and Shell support
Christopher Smith
cssmith at gwmail.gwu.edu
Thu May 12 17:03:15 UTC 2011
Hello all,
My name is Scotty Smith. I'm a Ph.D. student at the George Washington
University, currently researching programming
language constructs for supporting robotic planning applications.
My project [1] involves the creation of a Lua library, which will allow
Lua scripts to be executed in RTEMS, as well as a
configuration so that Lua can be used as a shell in RTEMS. Also with this
project, a Python to Lua translator will be developed,
which will allow some Python scripts to be executed in RTEMS through the Lua
library. The full proposal can be found here: [2].
[1] http://rtems.org/wiki/index.php/Lua_Port_and_Python_Translator
<http://rtems.org/wiki/index.php/Lua_Port_and_Python_Translator>[2]
https://docs.google.com/a/gwmail.gwu.edu/document/d/1oQipF8_ynwi-Fzb2dFTc3A0bCbn8AY519EvrjUZgYfY/edit?hl=en&authkey=CNj47vkH#
[3]
-- Scotty
URL: <http://lists.rtems.org/pipermail/users/attachments/20110512/612a274f/attachment.html>
