Ada support in current RTEMS versions ?
Simon Clubley simon.clubley at googlemail.com
Wed May 25 12:59:34 UTC 2011
On 25 May 2011 13:08, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 05/25/2011 06:37 AM, Ralf Corsepius wrote:
>> On 05/25/2011 01:14 PM, Simon Clubley wrote:
[snip]
>>> (I'm probably going to write a new BSP in a month or two and as I am
>>> currently using RTEMS 4.9.2, I am thinking about moving forward to a
>>> more recent RTEMS version at the same time.)
>> Independently of Ada (The Ada issues basically are the same with both
>> versions), I'd recommend to use at least RTEMS-4.10 (or even CVS-HEAD)
>> for new developments, because the rtems-4.9.x series is "in deep freeze".
> Definitely agree there.  Don't jump to the head for this unless
> something forces you to. A couple of cases I know where you
> would end up on the head are for a new CPU model which is only
> supported on the head, you might have to use the head.
> You require a feature which is only supported on the head.
> Hopefully neither apply.
No, they don't and thanks for the detailed reply. Given Ada's problems
with gcc at various points over the years, I just wanted to make sure
there wasn't a new fundamental problem with Ada I wasn't aware of.
I'll wait for a bit after 10.1 is released and then use that as my new version.
Thanks (and thanks for your continued Ada support),
Simon.
Simon Clubley
