GSoC2011Project--RTEMSPortOfGCJ
Jie Liu lj8175 at gmail.com
Thu May 12 12:54:09 UTC 2011
2011/5/12 Anthony Green <green at moxielogic.com>
> On 5/12/2011 8:01 AM, Jie Liu wrote:
>> Hi all,
>> I am a master student of computer science at Beijing University of Posts
>> and Telecommunications in China.My GSoC2011 Project of RTEMS is “RTEMS
>> port of the GNU Java Compiler”[1] and the original project proposal can
>> be found on google docs[2].
> Hi Jie,
>  Great project!  I am one of those people who helped bring gcj to life
> starting back in the 90s, and am the author of libffi, which is used by
> libgcj.  Gcj was originally intended for embedded software devs, so I'm
> happy to see an RTEMS port in the works.
>  What processor architecture(s) will you be testing with?
Hi Anthony Green,
Very happy to receive your reply and nice to meet you.
I will use i386 for the initial porting. If this can be done in a short
time, I want to transfer to arm and then powerpc.
Best Regards,
Jie
> Anthony Green
>> The purpose of this project is to make the GCJ (GNU Compiler for Java ,
>> also called GJC: GNU Java Compiler) work with RTEMS. First of this
>> project is porting GCJ run-time to RTEMS, then run the GCJ Test Suite
>> for the porting, and last submit modifications to the related projects
>> such as GCC, RTEMS and so on. After completed this project, we can use
>> Java to program RTEMS applications.
>> Thank you for your time.
>> [1]http://www.rtems.org/wiki/index.php/GNUJavaCompiler
>> [2]
>> https://docs.google.com/document/d/1ww2nXP0JVOmhSR1xs3M-PkoIpxRtamj79CMHBmDpbmw/edit?hl=zh_CN#
>> PS: If you do not have the access permission for the project
>> proposal[2], please check it and ask for. I will give the permission to
>> you as soon as possible.
>> Best Regards,
>> Jie
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20110512/2ca1c095/attachment-0001.html>
