Problems with RTEMS installation
Mon May 23 09:48:51 UTC 2011
Hello,
please provide more information, e.g. the commands with parameters you execute
and the output including the actual error message.  The RTEMS 4.8.1 is quite
old.  Why do you build the tool chain yourself?  You can use the RPMs.
On 05/23/2011 11:43 AM, Konstantinos Papadopoulos wrote:
> I am currently involved in some projects related to testing of Real-Time
> Operating Systems including RTEMS for LEON3.
> I tried to build and install RTEMS toolchain based on the specific
> “Getting Started” Guide for performing some measurements, but I
> experienced some problems. It must be pointed out that the version of
> RTEMS used is 4.8.1 while the PC is running Ubuntu 11.04.
> During ‘make’, an error with the message “No acceptance cc found in
> $PATH” that causes the unsuccessful termination of this procedure
> occurs. This seems to happen because the cross compilation toolset may
> be ignored, since a message “checking for sparc-rtems-gcc… no” is
> performed before the aforementioned error (the same also happens with
> other components of cross compilation such as ‘sparc-rtems-strip’).
> Moreover, it must be pointed out that I do have the cross compilation
> toolset in our search path as the guide mentioned above advices us to
> do, while it is first in it to ensure that I am using the intended
> version of all tools. Finally, when I try to access these tools from an
> independent bash shell, they are recognized and run regularly. To
> summarize, I would like to ask you whether this problem has been
> previously referred and if there is any solution to overpass it.
> Thank you in advance,
> Konstantinos
> rtems-users mailing list
> rtems-users at rtems.org
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
