MVME162 BSP Issues
Hoover, Victor P CTR NAVAIR, AIR 4.1.3.3 victor.hoover.ctr at navy.mil
Wed Nov 2 16:57:04 UTC 2011
> The NIC is not yet supported.
Okay, if I make any progress at all I should be able to steal network
Code from the MVME167 BSP - my 162 and 167 boards (at least) use the
Same NIC chip.
> FWIW this looks like a pre-termios driver so it is possible that
> the input doesn't interface correctly.  Check that inbyte works
> and then refactor the driver to follow the "simple polled
> single port" template.  powerpc/psim has a nice example of
> this.  Basically inbyte/outbyte become support routines
> for a framework.
Yep, I had already dug through the console.c code for both the 162 and
167 BSPs and noticed that the 162 BSP didn't have the termios code.
> This is a very old BSP.  It was the first BSP ever submitted.
> Any updates will be appreciated.  I will review and merge
> them.
Hopefully I can get things working although it's going to be on a part
time basis.  I need to build a system to do some data capture but it's
currently a low priority project.
On the seriously bad side though I seem to have some problems with the
development tools.  I've discovered that the printf function doesn't
work right for me.  If I do a printf of a newline terminated string it
prints to the console.  If the string does not end with a newline or
if the string contains any kind of formatting commands (%s, %d, etc.)
then processor halts.  If I can't sort this out then trying to do any
kind of testing or development is going to be very tricky.
	- Vic Hoover
Type: application/x-pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20111102/3ae91366/attachment-0001.bin>
