Unable to reconfigure the stack size
Fabricio de Novaes Kucinskis
fabricio at satelite.dea.inpe.br
Tue Nov 22 03:27:09 UTC 2011
Hi Joel,
I used the constant you pointed, CONFIGURE_MINIMUM_TASK_STACK_SIZE and it
worked as expected. Good that it was something that simple. Thanks again!
But, just to warn and try to contribute a little: I tried to follow what's
described in the C User's Manual, and there is no reference to
"CONFIGURE_MINIMUM_TASK_STACK_SIZE". The manual refer to the constants I used.
Maybe it is outdated?
Regards,
Fabrício.
On Mon, 21 Nov 2011 11:19:00 -0600, Joel Sherrill wrote
> On 11/21/2011 11:31 AM, Fabricio de Novaes Kucinskis wrote:
> > Hi Joel, and thank you for this sunday answer!
> > So, RTEMS should have changed the stack size when I defined
> > CONFIGURE_MINIMUM_STACK_SIZE and used RTEMS_CONFIGURED_MINIMUM_STACK_SIZE
when
> > creating the task, but it didn't.
> The constant is CONFIGURE_MINIMUM_TASK_STACK_SIZE.
> Using the wrong name is certainly going to have no effect.
> Sorry I didn't see that on a Sunday.
> > (I think my other comments - stack checker error, STACK_SIZE and other
RTEMS
> > configs - can be ignored for now, for the good of the discussion.)
> Yep.
> > I'd like to know if someone on the list was able to change or not the
default
> > stack size for the ERC32/SIS BSPs. If someone have tried it, please report
if
> > it worked or not.
> Try the right constant name.
> One of the examples-v2/ticker/low_ticker variations shows how to use
> this and I know it works
> on sis because that is where my workspace size numbers in
> presentations came from.
> >>> You have pulled a lot of thread and looked for a horse (e.g. blown
> >>> stack) which it smells to me like a zebra (e.g. stray write onto stack
> > memory).
> > Among all the details I forgot to add that - remember, I was dizzy ;) -,
apart
> > from the size of the stack for the ISIS task (4036 bytes, almost at the 4
> > kbytes limit) a few instructions before the error, the local variable
which is
> > overwritten in the memcpy operation is inside the .bss area:
> > - Local variable address: 0x02058920
> > - End of .bss section: 0x0205c150
> > Also, the instruction that causes the overwrite seems to be preety safe:
> > memcpy(&destinationElement,&sourceElement, sizeof(Element)); [not exactly
> > this, but this is what it does]
> The instruction is safe .. but maybe not the destination address or
> contents of the source.
> > Finally, when I reduce the size of the arrays that are placed inside the
.bss
> > area (moving its end far from the RTEMS stack start), I have no error.
> Something else got corrupted. :)
> Since you know the memcpy is the culprit, is the destination correct
> given the source?
> Can you do a backtrace?
> > So, do you think this can be a bug in the ERC32 BSP? If so, where to look
at?
> > This whole stack configuration seems a little complicated to me.
> It isn't a BSP error. You are probably lucky it is reproducible. :)
> --joel
> > Thanks again,
> > Fabrício.
> > On Sun, 20 Nov 2011 10:18:06 -0600, Joel Sherrill wrote
> >> On 11/20/2011 09:19 AM, Fabricio de Novaes Kucinskis wrote:
> >>> Hello everybody,
> >>> I have an application that has blown the stack, tried a lot of
> >>> things to
> > fix
> >>> it, and up to now nothing worked. In fact, nothing that I've tried
> >>> so far
> > had
> >>> any effect on the stack size.
> >>> It's clear to me that I'm missing or misunderstanding something. In
> >>> order
> > to
> >>> discover what, follows a detailed description (sorry for the length)
> >>> of my problem, and what I've tried - my hope is that, by describing
> >>> in detail, I expose what I'm doing wrong and allow you to point it.
> >>> I'm using RTEMS 4.10.0 for the SIS BSP.
> >>> I have a task that demands more than the RTEMS default stack size
> >>> for the
> >>> ERC32 (I'm using SIS to try it, but I think this should not be an
issue).
> > At
> >>> some point a local variable is overwritten by a memcpy applied to a
> >>> large array in the .bss area, and the application falls in an infinite
> > loop.
> >> With sis you can use the watch command to find out where the write
> >> comes from. It may not be a stack overflow but a stray write that
> >> just happens to hit the stack.
> >>> Follows the stack report taken immediatelly before the blow:
> >>> Stack usage by thread
> >>> ID NAME LOW HIGH CURRENT AVAILABLE
USED
> >>> 0x09010001 IDLE 000205E2D0 - 000205F2DF 000205F0A0 4096 752
> >>> 0x0A010002 ISIS 0002060BB0 - 0002061BBF 00020617C8 4096 4036
> >>> 0xFFFFFFFF INTR 000205C5D0 - 000205D5CF 0000000000 4080 576
> >>> Memory exception at 2cbe13c (illegal address) Unexpected trap ( 9)
> >>> at address 0x02014228 data access exception at 0x02CBE13C
> >>> Note: the "Memory exception" error only happens when I enable the
> >>> stack checker, but I assume this is expected.
> >> Maybe.. maybe not.. :)
> >>> "Ok", I thought, "the default stack is not enough, so let's change
> >>> it" -
> > and
> >>> that's what I've been trying to do for the last couple of days, with
> >>> no success.
> >>> The first thing I tried was to change the stack size for the
> >>> application, setting CONFIGURE_MINIMUM_STACK_SIZE to 8 kbytes, and
> >>> changing the
> > creation of
> >>> the task, using RTEMS_CONFIGURED_MINIMUM_STACK_SIZE. But as a new
> >>> stack report has shown, it seems to have no effect on the stack size.
> > The
> >>> same goes for the CONFIGURE_EXTRA_TASK_STACKS #define.
> >> CONFIGURE_MINIMUM_STACK_SIZE and the change you made to
> >> rtems_task_create for the "ISIS" task should have changed its size to
> >> 8K.
> >> CONFIGURE_EXTRA_TASK_STACKS just reserves memory in the work space to
> >> account for tasks which are created with greater than minimum.
> >>> Starting to be worried, I've tried to change the start address of
> >>> the
> > RTEMS
> >>> work area by using CONFIGURE_EXECUTIVE_RAM_WORK_AREA, just to see
> >>> what happens. Again, nothing different.
> >>> To illustrate, follows the configuration with everything I tried.
> >>> The corresponding stack report is exactly the same as above.
> >>> #define CONFIGURE_MINIMUM_STACK_SIZE (1024 * 8)
> >>> #define CONFIGURE_EXTRA_TASK_STACKS (1024 * 8)
> >>> #define CONFIGURE_EXECUTIVE_RAM_WORK_AREA 0x02100000
> >>> #define CONFIGURE_STACK_CHECKER_ENABLED
> >> Hmmm... I think CONFIGURE_EXECUTIVE_RAM_WORK_AREA may not be honoured
> >> by most BSPs and is definitely NOT supported with the new shared
> >> workspace shared framework.
> >> Anyway, the sparc BSPs are definitely overwriting that field in
> >> 4.10 without honouring if it was NULL or not.
> >>> Now a little bit desperate, I went into the ERC32 BSP code. There is
> >>> a STACK_SIZE defined in the start.S file, but not used there. The
> >>> same is redefined in bspgetworkarea.c. But the way it is used
> >>> suggests to me that
> > the
> >>> RTEMS work area shall not touch into this area:
> >> Yes .. unfortunately that is defined in two (or three) places. :(
> >> But it has nothing to do with task stack size. It is the size of the
> >> stack that the BSP initialization runs on until the switch to the
> >> first task.
> >>> void bsp_get_work_area(...) {
> >>> /* must be identical to STACK_SIZE in start.S */
> >>> #define STACK_SIZE (16 * 1024)
> >>> *work_area_start =&end;
> >>> *work_area_size = (void *)rdb_start - (void *)&end -
STACK_SIZE;
> >>> Being "end" a symbol set at linkcmds.base, pointing to the end of
> >>> the .bss area, and "rdb_start" pointing to the end of RAM, I assumed
> >>> that RTEMS
> > sets
> >>> the ERC stack pointer to work_area_start + work_area_size, but this
> >>> seems
> > not
> >>> to be the case.
> >> From c/src/lib/libbsp/sparc/shared/start.S
> >> set (SYM(rdb_start)), %g6 ! End of RAM
> >> st %sp, [%g6]
> >> sub %sp, 4, %sp ! stack starts at end of
> >> RAM - 4 andn %sp, 0x0f, %sp ! align stack on 16-
> >> byte boundary mov %sp, %fp ! Set frame pointer
> >> nop
> >> The starting stack pointer is set to the end of RAM and grows down.
> >> The area from end of ram to "end of ram - STACK_SIZE" is the starting
> >> stack.
> >>> Digging deeper into the BSP code, I saw that _CPU_Context_switch
> >>> saves the registers, including the stack pointer (not touched by
> >>> RTEMS yet). At the first call to _CPU_Context_restore_heir, the stack
> > pointer is "restored"
> > to an
> >>> address that I couldn't relate to anything:
> >>> - work_area_start = 0x205c150 (end of the .bss section)
> >>> - work_area_size = 0x39feb0 (last RAM address - first free RAM
> >>> address -
> >>> STACK_SIZE)
> >>> - restored stack pointer at _CPU_Context_restore_heir = 0x20606f0
> >> Tasks stacks are from the RTEMS Workspace. That stack pointer
> >> (0x20606f0) is within the right address range since it is between
> >> work_area_start and its end. It is also properly aligned. I think
> >> that is correct.
> >> It looks to me that you have a stray write over something on the task
> >> stack. It could be as simple as someone writing too many bytes into a
> >> buffer on the stack that isn't that large.
> >> Step out of that and watch the %sp of the task. At some point, it
> >> must be going bad. It is doing that because it is being restored from
> >> RAM and that memory must have been written to unintentionally.
> >> This will sound hard but you need to figure out what address the bad
> >> %sp is coming from and set a watchpoint on accesses to it. At some
> >> point, the bad value will go in. Then you have your culprit.
> >> Then the question is to find the fix.
> >>> That's when I, already dizzy, stopped trying and decided to ask the
list.
> > It
> >>> shall be something (maybe elementary) that I'm doing wrong, but I
> >>> don't
> > know
> >>> what it could be, nor where to look at anymore.
> >> memory).
> >> --joel
> >>> Thanks for your time and best regards,
> >>> Fabrício Kucinskis.
