Where is sys/ioctl.h supposed to come from?
Peter Dufault
dufault at hda.com
Tue Oct 11 12:21:24 UTC 2011
I just noticed that this C code:
#include <sys/ioctl.h>
void foo(void){}
fails with:
[dufault at pico tmp]$ powerpc-rtems4.7.1-gcc -c foo.c
foo.c:1:23: error: sys/ioctl.h: No such file or directory
on ALL the rtems development environments I've got available going back to the above 4.7.1.
There are sys/ioctl.h files in the BSP subdirectories but not in the usual include/sys directory. For example, for the 4.11 I've got:
[dufault at finny12 tmp]$ find /opt/rtems-4.11/ -name ioctl.h -print
/opt/rtems-4.11/powerpc-rtems4.11/beatnik/lib/include/sys/ioctl.h
/opt/rtems-4.11/powerpc-rtems4.11/phycore_mpc5554/lib/include/sys/ioctl.h
What step have I been missing all these years? Here's a verbose trace, is it something to do with my nonexistent "sys-include" directory?
[dufault at finny12 tmp]$ cat foo.c
void foo(void) {}
[dufault at finny12 tmp]$ powerpc-rtems4.11-gcc -v -c foo.c
Using built-in specs.
COLLECT_GCC=powerpc-rtems4.11-gcc
COLLECT_LTO_WRAPPER=/opt/rtems-4.11/libexec/gcc/powerpc-rtems4.11/4.6.1/lto-wrapper
Target: powerpc-rtems4.11
Configured with: ../gcc-4.6.1/configure --prefix=/opt/rtems-4.11 --bindir=/opt/rtems-4.11/bin --exec_prefix=/opt/rtems-4.11 --includedir=/opt/rtems-4.11/include --libdir=/opt/rtems-4.11/lib --libexecdir=/opt/rtems-4.11/libexec --mandir=/opt/rtems-4.11/share/man --infodir=/opt/rtems-4.11/share/info --datadir=/opt/rtems-4.11/share --build=i686-pc-linux-gnu --host=i686-pc-linux-gnu --target=powerpc-rtems4.11 --disable-libstdcxx-pch --with-gnu-as --with-gnu-ld --verbose --with-newlib --with-system-zlib --disable-nls --without-included-gettext --disable-win32-registry --enable-version-specific-runtime-libs --enable-threads --disable-lto --disable-plugin --enable-newlib-io-c99-formats --enable-newlib-iconv --enable-languages=c,c++
Thread model: rtems
gcc version 4.6.1 20110627 (RTEMS gcc-4.6.1-7.fc14/newlib-1.19.0-17.fc14) (GCC)
COLLECT_GCC_OPTIONS='-v' '-c'
/opt/rtems-4.11/libexec/gcc/powerpc-rtems4.11/4.6.1/cc1 -quiet -v -Dmpc750 foo.c -quiet -dumpbase foo.c -auxbase foo -version -o /tmp/ccwiODAe.s
GNU C (GCC) version 4.6.1 20110627 (RTEMS gcc-4.6.1-7.fc14/newlib-1.19.0-17.fc14) (powerpc-rtems4.11)
compiled by GNU C version 4.5.1 20100924 (Red Hat 4.5.1-4), GMP version 4.3.1, MPFR version 2.4.2, MPC version 0.8.1
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
ignoring nonexistent directory "/opt/rtems-4.11/lib/gcc/powerpc-rtems4.11/4.6.1/../../../../powerpc-rtems4.11/sys-include"
#include "..." search starts here:
#include <...> search starts here:
/opt/rtems-4.11/lib/gcc/powerpc-rtems4.11/4.6.1/include
/opt/rtems-4.11/lib/gcc/powerpc-rtems4.11/4.6.1/include-fixed
/opt/rtems-4.11/lib/gcc/powerpc-rtems4.11/4.6.1/../../../../powerpc-rtems4.11/include
End of search list.
Compiler executable checksum: 418143d4d6b0120fd65a74d770b08579
foo.c:1:23: fatal error: sys/ioctl.h: No such file or directory
compilation terminated.
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
