Different behaviour of RTEMS in QEMU/i386 and SPARC
Constantine "chicky" Giotopoulos kotsosgiotopoulos at gmail.com
Mon Oct 31 08:58:57 UTC 2011
Hello everyone.
Using RTEMS 4.8.2, I create a single task that executes the code of
"paranoia.c" (it is included when installing RTEMS 4.8.2 in the path
.../rtems-4.8.2/testsuites/samples/paranoia/paranoia.c):
rtems_task Init( rtems_task_argument ignored )
rtems_status_code status; rtems_id id;
//Create and start the first task
status = rtems_task_create( rtems_build_name( 'T', 'A', '1', ' ' ), 1,
RTEMS_MINIMUM_STACK_SIZE, RTEMS_DEFAULT_MODES, RTEMS_DEFAULT_ATTRIBUTES |
RTEMS_FLOATING_POINT, &id);
assert( !status );
status = rtems_task_start( id, task1, 0 );
assert( !status );
status = rtems_task_delete( RTEMS_SELF );
exit( 0 );
rtems_task task1( rtems_task_argument ignored )
paranoia();
rtems_task_delete(RTEMS_SELF);
Paranoia program contains a number of functions that perform floating point
operations.
When I execute the aforementioned code on a SPARC machine it works
perfectly. But when I execute the same code using Qemu/i386 the execution
halts when "Milestone 140" is reached, and more specifically after the line
indicated bellow:
Milestone = 140;
printf ("\n");
/* ...calculate Exp2 == exp(2) == 7.389056099... */
X = Zero;
I = 2;
Y = Two * Three;
Q = Zero;
N = 0;
do {
   Z = X;
   I = I + 1;
   Y = Y / (I + I);
   R = Y + Q;
   X = Z + R;
   Q = (Z - X) + R;
while (X > Z);
Z = (OneAndHalf + One / Eight) + X / (OneAndHalf * ThirtyTwo);
X = Z * Z;
Exp2 = X * X;
X = F9;
Y = X - U1;
*printf ("Testing X^((X + 1) / (X - 1)) vs. exp(2) = %.17e as X -> 1.\n",
Exp2);*
for (I = 1;;) {
   Z = X - BInvrse;
   Z = (X + One) / (Z - (One - BInvrse));
  Q = POW (X, Z) - Exp2;
   if (FABS (Q) > TwoForty * U2) {
       N = 1;
       V9 = (X - BInvrse) - (One - BInvrse);
       BadCond (Defect, "Calculated");
       printf (" %.17e for\n", POW (X, Z));
       printf ("\t(1 + (%.17e) ^ (%.17e);\n", V9, Z);
       printf ("\tdiffers from correct value by %.17e .\n", Q);
       printf ("\tThis much error may spoil financial\n");
       printf ("\tcalculations involving tiny interest rates.\n");
       break;
   else {
       Z = (Y - X) * Two + Y;
       X = Y;
       Y = Z;
       Z = One + (X - F9) * (X - F9);
            if (Z > One && I < NoTrials)
                  I++;
            else {
                  if (X > One)
                        if (N == 0)
                               printf ("Accuracy seems adequate.\n");
                        break;
                  else
                       X = One + U2;
                       Y = U2 + U2;
                       Y += X;
                        I = 1;
Milestone = 150;
In other words, the program executes until the
Exp2);*
but stops there. If I comment out the section of the code, the rest of the
program executes normally.
What could be the case for this behaviour? Why is the code running smootly
on a SPARC but not on Qemu/i386 and how could I work out an explaination?
Thank you in advance.
URL: <http://lists.rtems.org/pipermail/users/attachments/20111031/4b3de43f/attachment.html>
