Small update to buildrt.t
Harmalkar, Subodh S. Subodh.Harmalkar at jhuapl.edu
Thu Oct 27 23:53:22 UTC 2011
Index: buildrt.t
RCS file: /usr1/CVS/rtems/doc/started/buildrt.t,v
retrieving revision 1.23
diff -r1.23 buildrt.t
158a159,162
> RTEMS source code building process uses GCC toolchain on your local host.
> It must be installed before you attempt to build RTEMS. Please type "gcc"
> at the command prompt and install it.
URL: <http://lists.rtems.org/pipermail/users/attachments/20111027/306906de/attachment.html>
