the environment variable BSP
Gedare Bloom
gedare at gwmail.gwu.edu
Sun Oct 16 15:14:34 UTC 2011
You seem a little confused about how to build RTEMS. Are you
following any of the documentation? For example:
http://www.rtems.com/wiki/index.php/Quick_Start or
http://www.rtems.com/wiki/index.php/GSoC_Getting_Started
On Sun, Oct 16, 2011 at 5:36 AM, Asma Mehiaoui <asma.mehiaoui at yahoo.com> wrote:
> i installed ubuntu 11.04 then i installed the following packages for RTEMS
> for two architectures:
> rtems-4.11-sparc-rtems4.11-binutils
> rtems-4.11-sparc-rtems4.11-gcc
> rtems-4.11-sparc-rtems4.11-gcc-c++
> rtems-4.11-sparc-rtems4.11-gcc-libgcc
> rtems-4.11-sparc-rtems4.11-gcc-libstdc++
> rtems-4.11-sparc-rtems4.11-gdb
> rtems-4.11-sparc-rtems4.11-newlib
> rtems-4.11-i386-rtems4.11-binutils
> rtems-4.11-i386-rtems4.11-gcc
> rtems-4.11-i386-rtems4.11-gcc-c++
> rtems-4.11-i386-rtems4.11-gcc-libgcc
> rtems-4.11-i386-rtems4.11-gcc-libstdc++
> rtems-4.11-i386-rtems4.11-gdb
> rtems-4.11-i386-rtems4.11-newlib
> could somebody tell me where i can find the BSP path to setup the
> environment variable RTEMS_BSP ?
> Thank's
> rtems-users mailing list
> rtems-users at rtems.org
