Network headers and __BSD_VISIBLE
Sebastian Huber
Thu Sep 8 07:01:36 UTC 2011
Hello,
if we do this
#include <sys/socket.h>
in RTEMS, then several features of the network stack are not visible since
__BSD_VISIBLE is undefined. This is in contrast to FreeBSD and Linux. FreeBSD
for example defines __BSD_VISIBLE in <sys/cdefs.h> depending on other defines.
The default is __BSD_VISIBLE defined to 1. Linux does not use __BSD_VISIBLE
and exports everything unconditionally.
We should do this similar to FreeBSD. Here is the part that defines
__BSD_VISIBLE in the current FreeBSD <sys/cdefs.h>:
http://svnweb.freebsd.org/base/head/sys/sys/cdefs.h?revision=218824&view=markup
* Deal with all versions of POSIX. The ordering relative to the tests above is
* important.
#if defined(_POSIX_SOURCE) && !defined(_POSIX_C_SOURCE)
#define _POSIX_C_SOURCE 198808
#endif
#ifdef _POSIX_C_SOURCE
#if _POSIX_C_SOURCE >= 200809
#define __POSIX_VISIBLE 200809
#define __ISO_C_VISIBLE 1999
#elif _POSIX_C_SOURCE >= 200112
#define __POSIX_VISIBLE 200112
#elif _POSIX_C_SOURCE >= 199506
#define __POSIX_VISIBLE 199506
#define __ISO_C_VISIBLE 1990
#elif _POSIX_C_SOURCE >= 199309
#define __POSIX_VISIBLE 199309
#elif _POSIX_C_SOURCE >= 199209
#define __POSIX_VISIBLE 199209
#elif _POSIX_C_SOURCE >= 199009
#define __POSIX_VISIBLE 199009
#else
#define __POSIX_VISIBLE 198808
#define __ISO_C_VISIBLE 0
#endif /* _POSIX_C_SOURCE */
#else
* Deal with _ANSI_SOURCE:
* If it is defined, and no other compilation environment is explicitly
* requested, then define our internal feature-test macros to zero. This
* makes no difference to the preprocessor (undefined symbols in preprocessing
* expressions are defined to have value zero), but makes it more convenient for
* a test program to print out the values.
* If a program mistakenly defines _ANSI_SOURCE and some other macro such as
* _POSIX_C_SOURCE, we will assume that it wants the broader compilation
* environment (and in fact we will never get here).
#if defined(_ANSI_SOURCE) /* Hide almost everything. */
#define __POSIX_VISIBLE 0
#define __XSI_VISIBLE 0
#define __BSD_VISIBLE 0
#elif defined(_C99_SOURCE) /* Localism to specify strict C99 env. */
#else /* Default environment: show everything. */
#define __XSI_VISIBLE 700
#define __BSD_VISIBLE 1
#endif
#endif
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
