when does rtems_rate_monotonic_period return TIMEOUT ?
Asma Mehiaoui
asma.mehiaoui at yahoo.com
Sun Sep 18 17:29:26 UTC 2011
Hello,
I'm runing this code of periodic task with rate monotonic period. I would like to test the case where task missed it's period, could someone help me to do it ?
I tried to put a loop within but that does not work (the loop does not end).
What does RTEMS do when rtems_rate_monotonic_period return TIMEOUT ?
rtems_task Task_Rate_Monotonic_Period(
rtems_task_argument unused
rtems_time_of_day time;
rtems_status_code status;
uint32_t ticks_since_boot;
rtems_name my_period_name;
rtems_id RM_period;
bool is_RM_created = 0;
uint32_t count;
while( 1 ) {
status = rtems_clock_get_tod( &time );
printf( "\n\nTask 2 - activating every %d second using rate monotonic manager to schedule (rtems_rate_monotonic_period)\n", PERIOD_TASK_RATE_MONOTONIC);
print_time( " - rtems_clock_get_tod - ", &time, "\n" );
ticks_since_boot = rtems_clock_get_ticks_since_boot();
printf(" - Ticks since boot: %" PRIu32 "\n", ticks_since_boot);
if( TRUE != is_RM_created ) {
count = 0;
my_period_name = rtems_build_name( 'P', 'E', 'R', '1' );
status = rtems_rate_monotonic_create( my_period_name, &RM_period );
if( RTEMS_SUCCESSFUL != status ) {
printf("RM failed with status: %d\n", status);
exit(1);
// Initiate RM period -- every N2 seconds
status = rtems_rate_monotonic_period(
RM_period,
rtems_clock_get_ticks_per_second() * PERIOD_TASK_RATE_MONOTONIC
exit(1);
is_RM_created = TRUE;
// Block until RM period has expired -- every N2 seconds
RM_period,
int x = 0;
while (x < 10000)
x++;
if( RTEMS_TIMEOUT != status ) {
printf("RM missed period!\n");
exit(1);
URL: <http://lists.rtems.org/pipermail/users/attachments/20110918/cac50164/attachment.html>
