when does rtems_rate_monotonic_period return TIMEOUT ?
Gedare Bloom
gedare at gwmail.gwu.edu
Mon Sep 19 15:39:08 UTC 2011
Your code is a little unusual. Normally you would do something like:
rtems_task Task_RM( ... ) {
rtems_rate_monotonic_create();
while (1) {
status = rtems_rate_monotonic_period();
PERIODIC_JOB_CODE
At the start of every iteration of the while loop the
rtems_rate_monotonic_period will either block the task until the
timeout occurs or return immediately with status == RTEMS_TIMEOUT if
the task missed its period (ran past its deadline).
So you might do something like:
while (1) {
if ( rtems_rate_monotonic_period(...) == RTEMS_TIMEOUT ) {
DEADLINE_MISS_CODE
PERIODIC_JOB_CODE
Basically, each call to period() sleeps on a timer that was set by the
last call (in case of deadline overrun no sleeping occurs) and sets a
new timer equal to the period duration when the previous period
expires.
Good luck!
Gedare
On Sun, Sep 18, 2011 at 1:29 PM, Asma Mehiaoui <asma.mehiaoui at yahoo.com> wrote:
> Hello,
> I'm runing this code of periodic task with rate monotonic period. I would
> like to test the case where task missed it's period, could someone help me
> to do it ?
> I tried to put a loop within but that does not work (the loop does not
> end).
> What does RTEMS do when rtems_rate_monotonic_period return TIMEOUT ?
> rtems_task Task_Rate_Monotonic_Period(
> rtems_task_argument unused
> rtems_time_of_day time;
> rtems_status_code status;
> uint32_t ticks_since_boot;
> rtems_name my_period_name;
> rtems_id RM_period;
> bool is_RM_created = 0;
> uint32_t count;
> while( 1 ) {
> status = rtems_clock_get_tod( &time );
> printf( "\n\nTask 2 - activating every %d second using rate monotonic
> manager to schedule (rtems_rate_monotonic_period)\n",
> PERIOD_TASK_RATE_MONOTONIC);
> print_time( " - rtems_clock_get_tod - ", &time, "\n" );
> ticks_since_boot = rtems_clock_get_ticks_since_boot();
> printf(" - Ticks since boot: %" PRIu32 "\n", ticks_since_boot);
> if( TRUE != is_RM_created ) {
> count = 0;
> my_period_name = rtems_build_name( 'P', 'E', 'R', '1' );
> status = rtems_rate_monotonic_create( my_period_name, &RM_period );
> if( RTEMS_SUCCESSFUL != status ) {
> printf("RM failed with status: %d\n", status);
> exit(1);
> // Initiate RM period -- every N2 seconds
> RM_period,
> rtems_clock_get_ticks_per_second() * PERIOD_TASK_RATE_MONOTONIC
> exit(1);
> is_RM_created = TRUE;
> // Block until RM period has expired -- every N2 seconds
> RM_period,
> int x = 0;
> while (x < 10000)
> x++;
> if( RTEMS_TIMEOUT != status ) {
> printf("RM missed period!\n");
> exit(1);
> rtems-users mailing list
> rtems-users at rtems.org
