"quit" in shell panics
Sebastian Huber
Fri Sep 2 13:19:40 UTC 2011
Hello,
I removed the "exit" and "quit" alias to the "fatal" command in the monitor
command list. You can still use the "fatal" command to call
rtems_fatal_error(). The "exit" and "bye" command will break the shell loop.
The "quit" command is not available.
Kind regards,
Sebastian
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
