Compile GSL with RTEMS
Espúreo Fernandez-Ulloa estados_espureos at yahoo.com.ar
Mon Sep 5 16:24:16 UTC 2011
Thanks for the quick answer and apologize for the blury description.
I've been following the GSL documentation to include the library on my example, to try it with RTEMS.
Set the linker flags " -lgsl -lgslcblas -lm" and included the path to the location where it's installed on my system.
However, the linker exits with an error, with the following description:
/opt/rtems-4.10/lib/gcc/sparc-rtems/4.4.5/../../../../sparc-rtems/bin/ld: skipping incompatible /usr/local/lib/libgsl.a when searching for -lgsl
/opt/rtems-4.10/lib/gcc/sparc-rtems/4.4.5/../../../../sparc-rtems/bin/ld: cannot find -lgsl
Thanks,
Elias
________________________________
De: Ralf Corsepius <ralf.corsepius at rtems.org>
Para: Espúreo Fernandez-Ulloa <estados_espureos at yahoo.com.ar>
CC: "rtems-users at rtems.org" <rtems-users at rtems.org>
Enviado: lunes, 5 de septiembre de 2011 12:19
Asunto: Re: Compile GSL with RTEMS
On 09/05/2011 04:44 PM, Espúreo Fernandez-Ulloa wrote:
> Hi,
> I've been working with RTEMS 4.10 for the LEON3 processor for a few
> months, and tried to include the GSL library to compile an ordinary
> example with no further results so far.
> Haven't found enough information on the web to understand how to
> correctly include it in a project.
> Does anyone have a suggestion to follow in order to get an application
> running GSL functions?
> Thanks in advance,
You are not providing sufficient details. What exactly is your problem?
Building gsl is close to being as trivial as cross-compilation can be:
E.g.
configure --host=sparc-rtems4.10 \
CC="sparc-rtems4.10 -mcyprus -msoft-float" \
<more options>
or
CFLAGS="-mcyprus -msoft-float"
<more options>
Ralf
URL: <http://lists.rtems.org/pipermail/users/attachments/20110905/b221a6b8/attachment-0001.html>
