how to reduce executable compiled file
Luca Cinquepalmi
cinquepalmi at planetek.it
Tue Apr 3 16:20:10 UTC 2012
Sorry! I answered in Italian:-)
It only reduce my exe file of some hundreds of bytes:-(
Il 03/04/2012 18.15, Rhenzo Losso ha scritto:
> Try to change some argument o sparc-rtems-objcopy such this line below:
> "sparc-rtems-objcopy -O binary name_of_source_ exe name_of_binary.bin"
> that is the "same" line I use on my ARM, excpet it arm-rtems-objcopy
> not sparc-rtems-objcopy.
> 2012/4/3 Luca Cinquepalmi <cinquepalmi at planetek.it
> <mailto:cinquepalmi at planetek.it>>
> In my Makefile I also use these commands:
> sparc-rtems-strip $@.exe
> sparc-rtems-objcopy --remove-section=.comment $@.exe
> but the final .exe file is always large, about 300KB from the
> original 3MB.
> Should I use other commands? Thanks
> Il 03/04/2012 18.04, Rhenzo Losso ha scritto:
>> Greetings,
>> Maybe you can use the sparc-rtems-objdump or sparc-rtems-strip.
>> I'm using RTEMS on arm processor (CSN637 port) and I use
>> arm-rtems-objcopy to transform the arm.exe into arm.bin. It
>> reduce from 2MB to near 147kB.
>> Hi all,
>> I'm new of the list and I have a simple question. I compiled
>> a simple "Hello World" c code
>> with sparc-rtems-gcc, but the generated executable is about
>> 3MB, so much for my use...
>> I don't know why the executable file is so large... How can I
>> reduce its size?
>> Thank you
>> Luca
>> rtems-users mailing list
>> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>> http://www.rtems.org/mailman/listinfo/rtems-users
>> Rhenzo Losso
>> Bacharel em Ciência da Computação - UNESP / São José do Rio Preto
>> Instituto Tecnológico de Aeronáutica
>> Praça Marechal do Ar Eduardo Gomes, no. 50 - Sala 253 - Projeto
>> ITASAT
>> Vila das Acácias
>> 12228-900 Sao Jose dos Campos, SP, Brazil
>> +55 012 3947-6903 <tel:%2B55%20012%203947-6903> (Sala do ITA)
> Rhenzo Losso
> Praça Marechal do Ar Eduardo Gomes, no. 50 - Sala 253 - Projeto ITASAT
> Vila das Acácias
> +55 012 3947-6903 (Sala do ITA)
URL: <http://lists.rtems.org/pipermail/users/attachments/20120403/427a4022/attachment.html>
