how to reduce executable compiled file
Rhenzo Losso
rhenzo at gmail.com
Tue Apr 3 16:33:09 UTC 2012
I just made this test some right now on BSP SIS.
sparc-rtems-strip -s executable_name.exe -o strip-executable_name.exe
It was reduced a lot. from #MB to 140kB. After this I turn into binary.
sparc-rtems-objcopy -O binary strip-executable_name.exe
final-binary-name.bin
2012/4/3 Luca Cinquepalmi <cinquepalmi at planetek.it>
> Sorry! I answered in Italian:-)
> It only reduce my exe file of some hundreds of bytes:-(
> Il 03/04/2012 18.15, Rhenzo Losso ha scritto:
> Try to change some argument o sparc-rtems-objcopy such this line below:
> "sparc-rtems-objcopy -O binary name_of_source_ exe name_of_binary.bin"
> that is the "same" line I use on my ARM, excpet it arm-rtems-objcopy not
> sparc-rtems-objcopy.
>> In my Makefile I also use these commands:
>> sparc-rtems-strip $@.exe
>> sparc-rtems-objcopy --remove-section=.comment $@.exe
>> but the final .exe file is always large, about 300KB from the original
>> 3MB.
>> Should I use other commands? Thanks
>> Il 03/04/2012 18.04, Rhenzo Losso ha scritto:
>> Greetings,
>> Maybe you can use the sparc-rtems-objdump or sparc-rtems-strip. I'm using
>> RTEMS on arm processor (CSN637 port) and I use arm-rtems-objcopy to
>> transform the arm.exe into arm.bin. It reduce from 2MB to near 147kB.
>>> Hi all,
>>> I'm new of the list and I have a simple question. I compiled a simple
>>> "Hello World" c code
>>> with sparc-rtems-gcc, but the generated executable is about 3MB, so much
>>> for my use...
>>> I don't know why the executable file is so large... How can I reduce its
>>> size?
>>> Thank you
>>> Luca
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
>> Rhenzo Losso
>> Bacharel em Ciência da Computação - UNESP / São José do Rio Preto
>> Instituto Tecnológico de Aeronáutica
>> Praça Marechal do Ar Eduardo Gomes, no. 50 - Sala 253 - Projeto ITASAT
>> Vila das Acácias
>> 12228-900 Sao Jose dos Campos, SP, Brazil
>> +55 012 3947-6903 <%2B55%20012%203947-6903> (Sala do ITA)
> Rhenzo Losso
> Vila das Acácias
> +55 012 3947-6903 (Sala do ITA)
Rhenzo Losso
Vila das Acácias
URL: <http://lists.rtems.org/pipermail/users/attachments/20120403/62a2aac5/attachment.html>
