how to reduce executable compiled file
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 3 16:43:11 UTC 2012
Try sparc-rtems4.xx-size *.exe
The size can vary enormously based upon what you
are doing in application space.
--joel
On 04/03/2012 11:33 AM, Rhenzo Losso wrote:
> I just made this test some right now on BSP SIS.
> sparc-rtems-strip -s executable_name.exe -o strip-executable_name.exe
> It was reduced a lot. from #MB to 140kB. After this I turn into binary.
> sparc-rtems-objcopy -O binary strip-executable_name.exe
> final-binary-name.bin
> 2012/4/3 Luca Cinquepalmi <cinquepalmi at planetek.it
> <mailto:cinquepalmi at planetek.it>>
> Sorry! I answered in Italian:-)
> It only reduce my exe file of some hundreds of bytes:-(
> Il 03/04/2012 18.15, Rhenzo Losso ha scritto:
>> Try to change some argument o sparc-rtems-objcopy such this line
>> below:
>> "sparc-rtems-objcopy -O binary name_of_source_ exe
>> name_of_binary.bin"
>> that is the "same" line I use on my ARM, excpet it
>> arm-rtems-objcopy not sparc-rtems-objcopy.
>> In my Makefile I also use these commands:
>> sparc-rtems-strip $@.exe
>> sparc-rtems-objcopy --remove-section=.comment $@.exe
>> but the final .exe file is always large, about 300KB from the
>> original 3MB.
>> Should I use other commands? Thanks
>> Il 03/04/2012 18.04, Rhenzo Losso ha scritto:
>>> Greetings,
>>> Maybe you can use the sparc-rtems-objdump or
>>> sparc-rtems-strip. I'm using RTEMS on arm processor (CSN637
>>> port) and I use arm-rtems-objcopy to transform the arm.exe
>>> into arm.bin. It reduce from 2MB to near 147kB.
>>> Hi all,
>>> I'm new of the list and I have a simple question. I
>>> compiled a simple "Hello World" c code
>>> with sparc-rtems-gcc, but the generated executable is
>>> about 3MB, so much for my use...
>>> I don't know why the executable file is so large... How
>>> can I reduce its size?
>>> Thank you
>>> Luca
>>> rtems-users mailing list
>>> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>> Rhenzo Losso
>>> Bacharel em Ciência da Computação - UNESP / São José do Rio
>>> Preto
>>> Instituto Tecnológico de Aeronáutica
>>> Praça Marechal do Ar Eduardo Gomes, no. 50 - Sala 253 -
>>> Projeto ITASAT
>>> Vila das Acácias
>>> 12228-900 Sao Jose dos Campos, SP, Brazil
>>> +55 012 3947-6903 <tel:%2B55%20012%203947-6903> (Sala do ITA)
>> Rhenzo Losso
>> Bacharel em Ciência da Computação - UNESP / São José do Rio Preto
>> Praça Marechal do Ar Eduardo Gomes, no. 50 - Sala 253 - Projeto
>> ITASAT
>> Vila das Acácias
> Rhenzo Losso
> Praça Marechal do Ar Eduardo Gomes, no. 50 - Sala 253 - Projeto ITASAT
> Vila das Acácias
> +55 012 3947-6903 (Sala do ITA)
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20120403/555aca36/attachment.html>
