run example applications
domenico.dileo at unina.it domenico.dileo at unina.it
Tue Apr 24 15:42:50 UTC 2012
Hello,
I want to compile the example applications available at:
http://www.rtems.org/wiki/index.php/Example_Application_Compiling
 From the instructions there,
we have to :
a) run make install in the rtems build directory
b) move to the example folder, create the variable RTMES_MAKEFILE_PATH
and invoke make
I suppose that the with a) we
define the environment variables PROJECT_ROOT and RTEMS_CUSTOM
needed in the Makefile of the examples
If I  don't want to run the make install in rtems build directory
and I want to directly assign a value to these variables,
what should I write?
PROJECT_ROOT= is the top folder of the rtems tree ( in which
there is the rtems code itself,  the testsuite and  so on)
RTEMS_CUSTOM = ?
Thank you in advance for your help
Domenico
