run example applications
    Sebastian Huber
    Thu Apr 26 08:08:35 UTC 2012
On 04/24/2012 05:42 PM, domenico.dileo at unina.it wrote:
> If I  don't want to run the make install in rtems build directory
> and I want to directly assign a value to these variables,
> what should I write?
Why do you not want to run "make install"?  You can select an installation
prefix with "--prefix=XYZ" at the configure command line.  You can also use
"make DESTDIR=XYZ install".
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
