Pin Reading
Binkowski, Cassio
cassioiks at gmail.com
Mon Apr 2 13:34:45 UTC 2012
On Mon, Apr 2, 2012 at 9:58 AM, Sebastian Huber <
> On 04/02/2012 02:45 PM, Binkowski, Cassio wrote:
>> Hi Sebastian,
>> I'm interested in three of them: ARM, AVR and SPARC.
>> But if I want any other board, is there a way of looking for this
>> information?
> You have to look in the BSP source code, e.g. the header files. The
> lpc24xx ARM BSP has for example this API:
> http://git.rtems.org/rtems/**tree/c/src/lib/libbsp/arm/**
> lpc24xx/include/io.h<http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lpc24xx/include/io.h>
I'm afraid I didn't find any READ method.
I found just a GET, and it returns a boolean:
*static inline bool lpc24xx_gpio_get(unsigned index)
if (index <= LPC24XX_IO_INDEX_MAX) {
unsigned port = LPC24XX_IO_PORT(index);
unsigned bit = LPC24XX_IO_PORT_BIT(index);
return (LPC24XX_FIO [port].pin & (1U << bit)) != 0;
} else {
return false;
Can you advise?
Thanks
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120402/9a30b35d/attachment-0001.html>
