Pin Reading
Binkowski, Cassio cassioiks at gmail.com
Wed Apr 4 13:29:19 UTC 2012
On Mon, Apr 2, 2012 at 10:34 AM, Binkowski, Cassio <cassioiks at gmail.com>wrote:
> On Mon, Apr 2, 2012 at 9:58 AM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 04/02/2012 02:45 PM, Binkowski, Cassio wrote:
>>> Hi Sebastian,
>>> I'm interested in three of them: ARM, AVR and SPARC.
>>> But if I want any other board, is there a way of looking for this
>>> information?
>> You have to look in the BSP source code, e.g. the header files.  The
>> lpc24xx ARM BSP has for example this API:
>> http://git.rtems.org/rtems/**tree/c/src/lib/libbsp/arm/**
>> lpc24xx/include/io.h<http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lpc24xx/include/io.h>
>  I'm afraid I didn't find any READ method.
> I found just a GET, and it returns a boolean:
> *static inline bool lpc24xx_gpio_get(unsigned index)
>   if (index <= LPC24XX_IO_INDEX_MAX) {
>     unsigned port = LPC24XX_IO_PORT(index);
>     unsigned bit = LPC24XX_IO_PORT_BIT(index);
>     return (LPC24XX_FIO [port].pin & (1U << bit)) != 0;
>   } else {
>     return false;
> Can you advise?
Any thoughts on this?
Thanks.
URL: <http://lists.rtems.org/pipermail/users/attachments/20120404/2e054cfb/attachment-0001.html>
