Connection to bugzilla is untrusted ?
Jeff Mayes
Jeff.Mayes at OARcorp.com
Fri Apr 27 18:03:44 UTC 2012
The site uses a self-signed certificate. If you install the certificate on your machine, the problem should go away.
Thanks
Jeff
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: Friday, April 27, 2012 12:40 PM
> To: Kate Feng
> Cc: rtems-users at rtems.org; Jeff Mayes
> Subject: Re: Connection to bugzilla is untrusted ?
> I thing has something to do with the machine having multiple names. Jeff can
> explain.
> On 04/27/2012 09:08 AM, Kate Feng wrote:
> > Hi,
> > Whenever I try to access the site at
> > https://www.rtems.org/bugzilla/show_bug.cgi?
> > I always recevie the message below. Some people told me that they
> > could not access it. Thankfully, it is always OK with other RTEMS
> > sites.
> > Could the link connection for bugzilla be fixed, please ? Please advise.
> > This Connection is Untrusted
> > You have asked Firefox to connect securely to
> > www.rtems.org, but we can't confirm that your connection is secure.
> > Normally, when you try to connect securely, sites will
> > present trusted identification to prove that you are going to the
> > right place. However, this site's identity can't be verified.
> > www.rtems.org uses an invalid security certificate.
> > The certificate is not trusted because it is self-signed.
> > The certificate is only valid for rtems.org
> > (Error code: sec_error_untrusted_issuer)
> > Regards,
> > Kate Feng
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
