Connection to bugzilla is untrusted ?
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Apr 27 17:40:12 UTC 2012
I thing has something to do with the machine having
multiple names. Jeff can explain.
On 04/27/2012 09:08 AM, Kate Feng wrote:
> Hi,
> Whenever I try to access the site at
> https://www.rtems.org/bugzilla/show_bug.cgi?
> I always recevie the message below. Some people told me that
> they could not access it. Thankfully, it is always OK with other RTEMS
> sites.
> Could the link connection for bugzilla be fixed, please ? Please advise.
> This Connection is Untrusted
> You have asked Firefox to connect
> securely to www.rtems.org, but we can't confirm that your connection is
> secure.
> Normally, when you try to connect securely,
> sites will present trusted identification to prove that you are
> going to the right place. However, this site's identity can't be verified.
> www.rtems.org uses an invalid security certificate.
> The certificate is not trusted because it is self-signed.
> The certificate is only valid for rtems.org
> (Error code: sec_error_untrusted_issuer)
> Regards,
> Kate Feng
Joel Sherrill, Ph.D. Director of Research& Development
