Supported ARM BSPs
Fered a_Fered at yahoo.com
Mon Apr 30 03:25:48 UTC 2012
Can I add these BSPs to 4.10?
Thanks.
Gedare Bloom wrote:
> The boards you listed are available in the development branch of RTEMS
> (git repository head, aka 4.11). So the easiest thing would be to use
> 4.11 if that is an option for you. I'm unsure about the bsps available
> in 4.10 without going to look at the source. You can find them in
> c/src/lib/libbsp/arm/ subdirectories. BSP variants are defined in the
> make/custom/*.cfg files within a bsp's subdirectory.
> -Gedare
> On Sun, Apr 29, 2012 at 1:22 AM, Fered <a_Fered at yahoo.com> wrote:
> > I want to prepare a board that RTEMS has a BSP for it. It seems that the
> > website is not reliable!
> > Please tell me if BSP of any Cortex based board is available and how can
> > I use it.
> > Thanks a lot.
> > Fernando Nicodemos wrote:
> >> Dear Fered,
> >> There is also the csb637 bsp which is a variant of csb337.
> >> Unfortunately i did not work with these bsps yet. I tried to find them
> >> also and itsnames but i could not. Maybe they are variants of other
> >> bsps but are not described well in wiki with proper names.
> >> Regards
> >> Em sábado, 28 de abril de 2012, Fered escreveu:
> >> > Hi;
> >> > In RTEMS website, I see following BSPs are impelemented:
> >> >    - NXP LPC17XX (pin compatible to LPC24XX with ARM Cortex-M3
> >> > core)
> >> >    - Stellaris Microcontroller LM3S6965
> >> >    - STMicroelectronics STM32 F4
> >> > I work with RTEMS-4.10.2 and only following BSPs are in the
> >> > source:
> >> > csb336, csb337, edb7312, gba, gp32, nds, rtl22x, rtl22xx_t,
> >> > smdk2410
> >> > How can I add those 3 BSPs?
> >> > Those 3 items, are names of micro controllers. We have BSP of any
> >> > board that use those micro controllers?
> >> > Thanks
> >> Sent from Gmail Mobile
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
