Cheap big-endian board
Mathew Benson mathew.benson at gmail.com
Fri Aug 3 20:26:38 UTC 2012
I would like less than 120 Euros.  I don't have a JTAG debugger of my own, but that's a reasonable required tool.  Any recommendations there would be appreciated too.  Again, must be cheap or free (home built / open source).
Yes, I preferred PowerPC but didn't find anything even close to my budget so I considered all PowerPC out.
I want to be able to use QEMU or another sim primarily through development but need at least one set of actual hardware units for demonstration purposes.  After completion, I'd like to give the user the option of real or simulated.  I'm just concerned that the simulated environment won't work for users that need real time performance.
The Gumstix look great, if it wasn't for the little endian tool chains that I keep finding.
Sent from my iPhone
On Aug 3, 2012, at 3:17 PM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> Hi,
> what is your budget in Euros?  Do you have a JTAG-Debugger.  I think the PowerPC evaluation boards are in general much more expensive than the ARM boards.  What about using a simulator, e.g. Qemu, PSIM (for PowerPC) or GDB (for SIS BSP on SPARC)?
> On 03/08/12 18:35, Mathew Benson wrote:
>> I have never used RTEMS, but would like to prototype some ideas for
>> using RTEMS on the job.  I have no budget for a demo or prototype, so
>> I'm looking for cheap development boards.  Can somebody recommend
>> cheap dev boards with the following criteria:
>> - RTEMS BSP available or easy to tailor or create one
>> - Big endian CPU (I'm porting code from an already existing big endian
>> project and don't want to byte swap)
>> - Inexpensive (preferably in the same price range as Beagleboard or Gumstix)
>> - Equivalent processing speed to a 400 MHz Pentium II or better
>> - Preferably no less than 128 MB of RAM
>> - Ethernet
>> - Programmable via USB, serial, or ethernet
>> I've been going through the platforms listed on the BSP wiki page but
>> haven't found a good one yet.  I understand both Beagleboard and
>> Gumstix are bi-endian, but all the toolchains I find are setup for
>> little endian.  Ideally, I would love to use the Gumstix.  Can that be
>> setup big endian easily?
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
